I haven’t found/seen one, to control circulators in RFH system. I emailed a coupla thermostat manufacturers, asking, but haven’t received a reply. Do you just get a regular thermostat, and use a relay of some sort, as with typical HVAC systems? Is this something most electricians would know how to put together? And are relays pretty cheap and easy to come by?
While no home can be completely fireproof, implementing these fire-resistant details can increase resilience.
We used regular Wirsbo t-stats w/ relays to the pumps. Later, for more control, we wired in a Magic Module, an awesome programmable logic controller from Elk Products. The relays should be only a few bucks and readily available. Not being the electrical guy who designed and wired this, I have just exhausted all my knowledge of it.
*Jim, Cloud is right. There are many more options in 24-volt T-stats than in 120-volt ones. And 24-volt to 120-volt relays are readily available. If you really want a 120/240-volt programmable, I probably have one laying around. I had to order one up for some odd-ball application and then didn't use it. I agree that they are not easy to find. -David
*I used taco 007 cartridge circulators with a built in 24 relay. they are pretty inexpensive, and work good. I control them directly with a 24 V thermostat, although I expect to design a more sophisticated control system in the future. If these weren't available I probably would have bought a fan control relay for a forced air furnance to control the circulator.http://www.taco-hvac.com/product.html
*Thanks, guys. Been rushed up/busy last coupla days, but will check into all these, as usual, helpful replies.
