proper wire sizing for run from generator in garage to house
user-133125 | Posted in Energy, Heating & Insulation on November 14, 2012 05:26am
Hi,
I’ve been reading up on all my electrical how-to books and consulting Code Check, but I’m still unsure about how to size my wires for this project.  Here are the details:
Generac 5500 watt generator out by the garage.  I’d like to plug the generator in here, have a cable carry the power to the transfer panel in my basement.
I have a free 2″ buried pvc pipe already in place that comes up through the garage floor and exits just outside of the house.  Perhaps the previous owners wanted to do something like this?
The distance from the garage to the house is 75′
The transfer panel is a a Reliance 10 circuit 30 Amp panel.
Normally, I’d say that a 10 gauge wire would be fine for carrying a 30A load.  Would the distance dictate that I go down to an 8?
Even though the wire will be carried in a plastic conduit, would code require I use a UF rated cable rather than NM?
Lastly, would I need to use a cable, or would it be kosher to use individual wires?
Thanks guys.
Tom
  1. DanH | Nov 14, 2012 09:32pm | #1
    Find any of several wire size calculators on the web, to find out if you need larger wire for the 75-foot run.
    You can use individual wires so long as the wires are entirely contained inside conduit.  In fact, individual wires generally can carry more current than the same wires in cable.
    1. user-133125 | Nov 14, 2012 11:24pm | #2
      Stranded vs. solid?
      Thanks Dan.  Any difference in carrying capacity between stranded and solid wire?  My first impulse is solid would be better but I don't have data on that.
  2. pmfl | Nov 16, 2012 01:24am | #3
    I would run # 6 thwn or thhn2 individual wires to make sure that you dont have any voltage or amperage drop over the 75 feet. According to the code, wires run underground( even through conduit) must be rated for wet locations.
    1. user-133125 | Nov 19, 2012 10:04am | #4
      Better safe
      Thanks everyone for taking the time to respond.  It probably can't hurt to do a little overkill on this, particularly since I'll be (hopefully) using this infrequently.  I think I'll stick with #8 wet location wire.
      Tom
