Pros and cons of holding the sil back 1/2 to allow sheathing to be flush and letting overhang?
HI there,
I will explain the method we use for detailing sills and sheathing on a slab foundation. Some of the details are simply hold-overs based on tradition going back quite a few years. The first detail and question you are asking about is whether or not to let the sheathing overhang the slab edge. Most builders, including myself, let the sheathing overhang the slab edge by about 1". The reason for this is to cover the joint between the top of the slab and the sill. This is a weather and wind detail that is less important now given materials and technology we have now. To me, it is still just a smarter detail than to have the sheathing cover just the sill. The sills, as you mentioned, need to be square regardless of whether the slab is. Sometimes this means letting the plates overhang the slab up to 1". All of the plates should overhang or be flush with the slab edge. Plates installed inside the slab edge willl cause the sheathing to bulge where it overhangs the slab. You are right to consider the vulnerability of the exposed sheathing edge to weather damage, but whether or not the sheathing overhangs the slab a bit or not, does not matter. All wood has to be at least 8" above finish grade regardless of how much it overhangs (or doesn't). That distance combined with proper drainage, grading, etc. should keep that exposed sheathing edge dry. As for the back of the sheathing being in contact with the slab, the contact, if there is any, should be moderate and not a concern. In really wet areas, or areas with destructive insects, it is a good practice to start the sheathing with 18" - 24" rips of treated ply. Regardless of the sheathing material, we always start with 12" Vycor that wraps the bottom edge of the sheathing, then paper, drainage, siding, etc. That's my take on it.
Wrap the bottom edge of the sheathing with flashing tape then run it an inch past the concrete. The sheathing is safe from rot and the lap prevents water intrusion.
