I am building a workshop in a detached garage what is the best way to protect metal surfaces such as saw tables and also hand tools? Will the protection cause any problems with applying poly or shellac to any boards worked over those surfaces?
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
