Protecting pipe insulation
Chris9 | Posted in General Discussion on August 12, 2003 02:35am
Help!
Ten years ago I used a brush-on coating to protect roof top neoprene pipe insulation in a solar installation from UV damage. Called Halstead 67 x 944 Protective Coating, it was manufactured by Halstead in Greensboro, NC, (P.O. Box 2050) and it worked extremely well. Now I can’t find the product or the manufacturer, or a good alternative to keep the sun from chewing up pipe insulation. I’d welcome any suggestions in locating Halstead or a good alternative to protect pipe insulation from UV damage. Thanks.
Chris9
    BillHartmann | Aug 12, 2003 05:45pm | #1
    Here are links to a couple of distributors.
    http://www.sigsouthwest.com/distributionintl/index.html?menu.html&header1.html&mfg.html
    http://www.materialsurvey.com/directory/15410.htmlhttp://www.materialsurvey.com/directory/15410.html
    If they don't have it maybe they know of similar products.
    1. Chris9 | Aug 23, 2003 03:16am | #3
      Bill,
      Thanks for the sources.  I'll give them a try.
      Chris
  2. WayneL5 | Aug 13, 2003 12:06am | #2
    You can wrap a sheet material around it.  In industrial applications insulation is often wrapped with plastic or aluminum sheet, made especially for this.  One supplier is http://www.mcmaster.com , an industrial supply company.  A local plumbing supply house should be able to get it two.  It's often called "jacketing", and usually comes in a 3' wide or so roll.  You can wrap elbows and joints with aluminum duct tape (real aluminum, not aluminum colored cloth) or purchase pre-formed fitting covers to match the jacket.
    1. Chris9 | Aug 23, 2003 03:18am | #4
      Chris
  3. 4Lorn2 | Aug 25, 2003 12:36am | #5
    I don't know if this will work in this application but I often use common latex paint to protect plastics, electrical conduits and PVC junction boxes, from UV damage. The electrical plastics are UV resistant but a few years in the Florida sun still takes a toll. I have found that any good exterior house paint, sometimes selected for nice subdued color to blend with plantings, makes a world of difference.
    I also suspect that house paint might be both more readily available and less expensive than a more specialized coating.
