Protecting the bottom edge of sheeting that is close to ground.
SawnOffFingers | Posted in Construction Techniques on November 25, 2019 01:03pm
I am  rebuilding a garage on the existing foundation about 50 years old.  The foundation has a drop ledge for the sheeting about an inch.  Unfortunately some of the sheeting is very close to grade – perhaps only 2-3″ away.  I would like to protect the bottom edge of the sheeting.
The new garage will have a rainscreen and WRB barrier, with Hardy panel siding.
One suggestion was to wrap WRB under the sill, then around the bottom of the sheeting, and then about 18″ up the wall.  The reat of the WRB will be layed on as normal.  My concern is there is then no drain at all for the sheeting and if any moisture gets in there it will surely cause rot.
Another usggestion was to dig out a trench 12″ deep, line with landscape fabric and 3/4 drain rock.
Any suggestions?  Attached are a couple of cross sections showing the wall construction.
  1. calvin | Nov 25, 2019 07:41pm | #1
    Remember Hardy recommends 6” clearance between the panel and the ground. 1” - 2” between siding and walk or drive........
  2. user-3976312 | Nov 25, 2019 08:32pm | #2
    Hey,
    Your question is one I'm dealing with on my own house, except that the wall I have is sitting on exposed ledge so improving drainage is out of the question.
    The WRB and rainscreen are a good start. What I plan to do is use one of the spreadable WRB products on the lower couple feet of the sheathing, paying attention to the end of the panels. Also plan to make a flashing detail on the bottom of the rainscreen gap to exclude vermin and deflect splashing , but still allow venting. The wall I have is below the roof slope so a gutter is mandatory to control the extra water coming off the roof and limit splashback. Of course this is also the north side of the house so drying will be limited, but I think that stopping any wetting will go a long way in avoiding problems.
    If I had the option I would improve the drainage with a gravel bed and drainage pipe, which I'm doing in another spot.
    1. ktkcad | Nov 28, 2019 02:04pm | #5
      The exposed ledge is not dirt. You will be good to grind the ledge to slope away from the house and eliminate any standing water. Think of it as organic concrete.
      1. user-3976312 | Nov 28, 2019 08:47pm | #6
        Ktkcad, Actually, the exposed ledge in my case slopes toward the wall, so there is no amount of grinding that will reverse that. Best that could happen is blast a channel parallel to the wall. But at least the bottom of the wall has enough space that I've put masonry in place that is tied into the ledge. The sheathing is about 4" above the ledge at it's lowest.
  3. florida | Nov 25, 2019 08:39pm | #3
    Use Zip sheathing then wrap the bottom edge with ZipTape. Start your siding with a 1 X 8, 1 x 10 or 1 X 12" run of PVC trim, a Z flashing then your Hardi starter course.
  4. mike_augustine | Nov 25, 2019 10:22pm | #4
    If you're taking it down to the foundation anyway, why not add a couple courses of block?
    If that's not an option, I'm with you I don't love the idea of wrapping the WRB, but wrapping tape around the bottom edge and then taping the WRB to that would be good. You want some kind of capillary break between the foundation ledge and sheathing anyway. You could use pressure-treated plywood for the lower course of sheathing and then tape the WRB to the foundation with a high-quality tape compatible with both. Then start the siding with a Boral or PVC skirt board to keep the fiber cement high enough. Design-in decent roof overhangs if you can. Keeping bulk water off the walls is key.
  5. makita888 | Dec 21, 2019 02:42pm | #7
    I always wrap bottom edge of sheathing with 6" Vycor snap a line on exposed side of sheathing at 4" Tack vycor on line and wrap around bottom edge and tack on the back side
  6. DanH | Dec 21, 2019 04:57pm | #8
    What I did, about 30 years ago, on a part of our house where the wall sat right next to a poured concrete entry slab, is replace the bottom 2 feet or so of sheathing with cement board. IIRC, I waterproofed the studs well before nailing. Seems to have worked.
  7. jlyda | Dec 22, 2019 12:01pm | #9
    Ideally the house would have not been constructed that way, but can’t change history.
    I’ve had similar issue on homes I’ve worked on in the past. A French drain tight to foundation works great. It will keep the water from building up in rain storm.
