Protective sleeve for gas piping
LarryY | Posted in Construction Techniques on March 2, 2008 04:54am
This is my first post although I have been “reading” for some time now.
What I like to know is whether piping for a natural gas line (1/2 inch black iron) that has been run through the back of a masonry fireplace from the gas meter outside to a gas fireplace (logs) needs to have some type of protective sleeve between the pipe and the masonry.  The gas fireplace was installed some years ago.  I do not belief there was a building perimit for this job.  I life in N. VA.  Thanks for any advice.
  1. plumbbill | Mar 02, 2008 07:33am | #1
    Some jurisdictions require a sleeve.
    My jurisdiction does not, but pipe in contact & passing through the masonry must be galvanized.
    “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
      LarryY | Mar 02, 2008 03:09pm | #2
      Thanks for the info.
      1. DanH | Mar 02, 2008 04:41pm | #3
        Minor point: Some buildings in Minneapolis (or was it St Cloud?) blew up some years back when gas from a broken line got into the buildings through the sleeve opening. So any sleeve should be well-caulked against both water and gas.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
