PT Lumber & Old Metal
TWG | Posted in General Discussion on September 5, 2007 05:38am
I have to replace some 4x4s with PT and the old pier anchors are not stainless or otherwise ideal for new PT wood.
If I ensure that all contact points between the PT and the anchors is seperated by a self-adhesive glazing, ala Grace Vycor, would this prevent the corrosion?
  1. rez | Sep 08, 2007 07:06pm | #1
    Greetings TWG,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    sobriety is the root cause of dementia.
  2. rez | Sep 11, 2007 07:03pm | #2
    Let's try this one more time.
    bump
  3. BillBrennen | Sep 11, 2007 07:26pm | #3
    Yes, the Vycor will prevent contact, eliminating the corrosion there. The fasteners are tricky. Galvanized will be good with the old metal, but not last in the wood. Stainless will last in the wood, but eat the old metal where it touches it. If the fasteners are big galvanized bolts, they can be coated with grease which will help them resist the new PT wood for longer.
    Bill
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
