PT Wood to Steel Attachment
Hector45 | Posted in Construction Techniques on April 9, 2008 05:48am
I’m building a porch that has a large span (24 feet) between posts.  The span is so large that a steel I-beam is required.  I plan on attaching a pressure-treated 2×6 to the top of the I-beam to provide a nailing surface for the joist hangers.
Here’s my question:  The new PT wood is reported to be quite corrosive to steel.  Do I need to put a barrier of some kind between the 2×6 nailer and the I-beam?  If so, what kind of barrier would you suggest?
Thanks!
“Listen, strange women lying in ponds distributing swords is no basis for a system of government.”
Jon
    Luka | Apr 09, 2008 09:22pm | #1
    Two layers of ice and water shield.
    Apply to the metal beam, and wrap down the sides a bit.
    Life is what happens when you would rather be finishing your own house.
    1. Hector45 | Apr 09, 2008 09:46pm | #2
      Thanks!
       "Listen, strange women lying in ponds distributing swords is no basis for a system of government."Jon
        Luka | Apr 09, 2008 11:12pm | #3
        You're welcome.=0)
    2. reinvent | Apr 10, 2008 02:23am | #6
      Or he could go with a stainless steel I beam.
        Luka | Apr 10, 2008 02:51am | #7
        Well heck, why stop there ? Why not an epoxy coated titanium i beam ?Or even better yet, gold plate the i beam...;o)The I&W is the standard solution here, and pretty cheap, for such a good solution.
        1. Hector45 | Apr 10, 2008 05:09pm | #8
          I like that stainless steel idea, but I think you guys missed the obvious solution...... Teak!  Actually, teak and stainless would look really sharp together.
          Oh, wait, I'm NOT insanely rich.  I guess I'll go with the I&WS."Listen, strange women lying in ponds distributing swords is no basis for a system of government."Jon
  2. frammer52 | Apr 09, 2008 11:27pm | #4
    why are you using  pt wood?
    interior application where there is no miosture no need for it
    1. Hector45 | Apr 09, 2008 11:31pm | #5
      It's a combination deck/screen porch, so this beam will see weather.  I should have been more clear in my original post.
Fast, Accurate Wall Framing
