Purpose of Small Rectangular Gaps in Brickwall?
user-5449330 | Posted in General Discussion on July 9, 2017 02:42am
All of the brick walls in our subdivision (my home included).  Have small gaps in the brick work about every 8ft.  I’m curious as to what these are for? Don’t think they are for drainage since a lot of the walls have other size outlets for drain pipes.  Also there are too many to be gutter/drainage outlets.  Seems that all of them are clogged.
  1. DanH | Jul 09, 2017 10:35pm | #1
    They are to drain water that gets behind the brick.  Most bricks veneer walls have them, but usually they are narrower (just a joint without mortar) and hence less noticeable.
    1. user-5449330 | Jul 10, 2017 07:07am | #2
      Thanks.....
        sawdust_steve | Jul 10, 2017 01:00pm | #3
        It's called a weep hole to drain water and there shoul dbe flashing behind it to channel water outward. A well installed weep should have an insect screen to stop the bugs from nesting in the wall cavity.
