Push to connect fittings?
kevinpdx | Posted in General Discussion on August 18, 2020 05:21pm
Hey guys, I’m replacing the shower valve in my master bath remodel and I’m wondering if this could be a diy job. I’ve got copper on there right now. Does everyone stay away from push to fit fittings in the shower or are they reliable. Has anyone used shark bite or John guest fittings regularly for valves? Should I replace the copper with pex for any reason? Should I just call a plumber (they are all about 3-4 weeks out)? Thanks as always!
  1. Shep | Aug 18, 2020 06:13pm | #1
    If you're doing permitted work, you may want to check with your local building department. Some codes don't allow SharkBites and similar in non accessible areas.
    1. kevinpdx | Aug 18, 2020 06:31pm | #3
      From what I've gathered they are allowed in walls in Oregon.
  2. mgmahan | Aug 18, 2020 06:29pm | #2
    I've never heard of any restrictions on Shark Bite fittings. The main disadvantage is the cost. I occasionally use them if I have to, but not simply for convenience. For a single job this might not be a problem. I've never heard of a failure. Code approval is a reliable recommendation.
    1. kevinpdx | Aug 18, 2020 06:32pm | #4
      It'll be cheaper than hiring a plumber in the long run, but only if they work.
    unclemike42 | Aug 18, 2020 08:26pm | #5
    If you can make clean cuts, and are up for a challenge, this is not out of DIY range.
    but make sure you leak check along the way, before things are sealed up.
    If you have never soldered, there would be a learning curve (good idea to practice after watching those u tube videos)
    Shark Bite fittings are a different discussion than the pex/copper question.
    You can get shower fixtures made for PEX use, and you could use crimp connectors vs shark bites. need a special tool, (or two or three), but again, you can compare tool costs with plumber costs, understanding that the experience of the DIY can be a benefit, or one more additional cost, depending on how things go.
    Free advice: expect it to leak the first time, no matter what you do. Be prepared. (don't turn the water back on and head out for coffee before checking the pipes for leaks)
    Also, I have a friend who has a bunch of low cost rental units, very old housing stock. he uses push to connect fittings, and never had one leak.
    1. mgmahan | Aug 18, 2020 08:52pm | #6
      Shark Bites work with both Pex and copper. I use PexPress fittings but the tools are very expensive. Definitely not DIY.
