PVC Door Trim
ddew | Posted in Construction Techniques on September 9, 2012 03:58am
I am wrapping my windows with 1×4 PVC trim and would like to do the same with my entry doors. Is PVC Trim stable enough to remove the wood brickmold on the doors and replace it with the PVC Trim? Can I attach a aluminum screen door to the PVC Trim? I would make the trim 1&1/4 thick just like the wood brickmold. I have not work with PVC Trim in this type of application.
Thanks for your help.
  1. calvin | Sep 09, 2012 05:34pm | #1
    I have firmly attached storm doors to pvc flat stock and their brickmold.
    I would securely fasten the trims and weld the corners together (pvc glue).
  2. calvin | Sep 09, 2012 05:53pm | #2
    Unless there's some pvc trim's available I'm not familiar with, you'll need to join or buildup their 3/4" with 1/2".   Buildup with rips along the edges I would "weld" and pin also b/4 fitting and assembly.
    PVC product available to me is full 3/4 and full 1".  Sheet goods are 1/2".  Azek and Koma.
    1. john7g | Sep 10, 2012 10:24pm | #3
      Had some 5/4 delivered today.  No 5/4 available for you?
      1. calvin | Sep 10, 2012 10:34pm | #4
        5/4, 1" actual, yes
        and I see now with a search that Azek has a frontier and an ATM that offers 6/4 or full 1-1/4".  But to my knowledge, even the local distributor to the yards here doesn't have any stock.
        I'll have to ask as it would come in handy.
        Probably have to get a bank loan and lock the trim in a vault overnite.................
        1. john7g | Sep 11, 2012 08:14am | #5
          hard to handle
          >get a bank loan and lock the trim in a vault overnite.............<
          LOL
          get it full length 18' with the sharp edges, too wiggly to move alone and too slippery & heavy to grab an arm load, too worried about slicing your hands open.
          Certainly not cheap though.  Once and done though is a good feeling.
          I couldn't find any 8" wide at 5/4 though.
