PVC Electrical Conduit – Unusual Use
Scott | Posted in General Discussion on July 26, 2011 07:13am
We’ve got a grey roof, grey deck, and grey gutters (see pic). So for downspout material I chose grey PVC electrical conduit. The color is right, it performs well, and is UV resistant.
But I’m faced with a few situations where I need to create a “plumbing” solution involving wyes and tees. I can’t find the fittings anywhere. Do they exist? If not, is there a workaround?
Thx.
  1. DanH | Jul 26, 2011 07:36pm | #1
    Can't help you with the fittings, but the most "unusual" use I've seen for PVC conduit is making snowshoes.
  2. calvin | Jul 26, 2011 07:50pm | #2
    Scott
    I think you might have to go back to metal (but-sizing for the males/females) to do the connections.  PVC Cond. has fittings but I've never seen anything like that.............
    How about another schedule 20/30/40 fit?
    Don't want it to look like an above the roof toilet however.
    1. Scott | Jul 26, 2011 08:28pm | #3
      Zackly.
      Luckily, most of the connections I need to make can be stashed under the deck. I'll look into your schedule 20/30/40 idea, but unfortunately it isn't available in the nice navy-grey like the conduit.
      Oh well.... it's the price you pay for these hillbilly ideas....
      1. calvin | Jul 26, 2011 08:41pm | #4
        Whelp,
        with a guy with no gutters and certainly no downspouts..............
        I don't have much info to share.
        1. Scott | Jul 26, 2011 10:24pm | #5
          Yeah, I hear ya.... woulda shoulda coulda. I've followed this debate for years.
          But the current design is best suited with gutters and downspouts.
  3. DanH | Jul 26, 2011 10:43pm | #6
    Maybe here: http://pvcfittingsdirect.com/ ?
    1. Scott | Jul 26, 2011 10:52pm | #7
      Good lead; thanks. This
      Good lead; thanks.
      This follows with Cal's suggestion to match sched 40 with PVC conduit. I have no idea if it will work, but at least it's all PVC, which means even if the joints are a bit sloppy, the cement should melt the stuff together.
      The results don't need to be pretty, just water-tight, most of it will be hidden.
      In hindsight I see I was a bit naive to think that wyes and tees would exist in the electrical world. I now see it's all about pull boxes and LB fittings.
      Live and learn.
      Thx.
      1. DanH | Jul 26, 2011 11:17pm | #8
        Worst case I'd think you could use some rubber fittings.  There are rubber versions of Ys and Tees.
        1. Scott | Jul 27, 2011 12:52am | #9
          Ahhhh..... forgot about that.   :-)
          I wouldn't even call that "worst case".
          In fact, the black/grey combo of rubber/grey conduit is prolly less offensive visually than transitioning to sched 40.
          Great idea.
          Next thing you know, Junkhound will be using Ferncos to route 3 phase underground to his shop!!!!
          {grin} {kidding}
