PVC Joints
Miroho | Posted in General Discussion on May 21, 2006 12:39pm
Used purple PVC cleaner and cement on one end of elbow, worked fine. Used same cleaner, cement and PVC on other end of elbow and it will not bind. Tried twice same results. Any idea as to why?
    Sphere | May 21, 2006 12:53am | #1
    Did ja give it a twist? Pressure in the pipe?
    Try a bong, wastes less.
    There is no cure for stupid. R. White.
    zachariah | May 21, 2006 05:19am | #2
    try gorilla glue for pvc no primer needed. no leaks.
    1. Miroho | May 21, 2006 04:43pm | #7
      Both times I cleaned, applied cement, twisted and held in place for 30-40 seconds. Have just cleaned it and will try using the gorilla glue. Thanks.
    2. Miroho | May 23, 2006 04:56am | #10
      The gorilla glue did it thanks.
        zachariah | May 23, 2006 05:21am | #11
        no problem, if that stuff won't do it nuttin will ;)
  3. hasbeen | May 21, 2006 05:22am | #3
    Did you wave the chicken bone over it from right to left or from left to right?
    "Doubt is not a pleasant condition, but certainty is absurd." Voltaire
      Sphere | May 21, 2006 05:40am | #4
      Hey Joe..lose about 6 of the ++++++ and we can see yer posts w/o scrolling..on our micromonitors..wadya say?
      1. hasbeen | May 21, 2006 05:47am | #5
        Damn, I gotta address the tag line thing, Duane. I can't decide if I'm too busy or too lazy, but I still have the link from Luka in my inbox to remind me to change it... so I will... later.++++++++++++++++++++++++++++++++++++++++++++++++++
          Sphere | May 21, 2006 05:51am | #6
          Hey. Pete wanted colored tags a few weeks ago/////I'd ahve to get a new fancy colored thing to see them..LOL
  4. WayneL5 | May 21, 2006 05:02pm | #8
    Are you sure all the components are PVC and not some other plastic?  Many plastics cannot be joined by cement at all, and some can only be joined with cements specifically designed for them.
    If you are doing large fittings the taper of the fitting can push the pipe out of it before it sets, so you have to keep axial compression applied for a minute or tow until the cement sets enough to stay in place.
    1. Miroho | May 21, 2006 06:30pm | #9
      Yes, fairly certain they are. What is puzzling is that a cut off from the same piece of pipe was cemented on the other end of the elbow. Tried the Gorilla Glue. Seems to be working. Will know for sure in a few hours.
  • A Postwar Comeback
