PVC Pipe – how tight?
wrudiger | Posted in General Discussion on March 27, 2007 06:13am
OK, so me and plumbin’ don’t get along so well…
…but I usually manage to get it in the end.  This one has me stumped.
Installing new PVC irrigation valves.  Supply side is 3/4″ female pipe thread.  So I got PVC male pipe thread to 3/4″ female slip PVC fittings. Followed my standard approach – 3 or so wraps of teflon tape & screw the fitting on, reasonably tight but not enough to split the fittings (I think).  6 out of 6 valves leaked at that fitting.
Round 2:  take it all back apart, replace male fitting with 3/4″ PVC nipple, then into female thread by female slip fitting – just like the other valves here.  Oh yea, used Rectorseal Tplus2 on the recommendation of the crusty old pro at the hardware store.  Tightened to hand tight plus a half turn or so.  Now only about half are leaking.  WTF???
The only thing I can come up with is that I’m over-tightening.  What is the standard for PVC to PVC threaded fittings?  Any other suggestions?
Wayne
  1. Abm | Mar 27, 2007 06:19am | #1
    If these are standard PVC fittings no pipe dope or other sealant is recommended.
    I always just give them a good tightening, not enough to break anything but good and tight...
    CapnMac | Mar 27, 2007 06:27am | #2
    Yeah, what Abm said, no tape or dope on pvc-to-pvc.
    When I was learning these things, I was told that taping or doping plastic threads actually keeps them from sealing, as you are seperating the planes that ming engage in a like-on-like mating.  Plastic threads also being cut to a slightly different specification than metal ones, as well.
    Wor irrgation fittings, I aim for "stong" hand tight, then only (caustion highly technical term here) a "squidgen" more (this, of course, assuming that the fitting has threaded all the way on--easy to see at eye level, less so, half under a sidewaly in the bottom half of a muddy trench).
