pvc trim
sawman99 | Posted in Construction Techniques on August 31, 2005 02:42am
I’m working with pvc trim for the first time and need to rout a cove detail in it.  Any suggestions as to router speed or any warnings?
  1. Shep | Aug 31, 2005 03:48am | #1
    I've found it works pretty much the same as pine; just use a sharp bit and don't try to cut too fast or too much at one time. I've usually used my P-C 1-1/2 hp router at whatever speed it runs at ( 20k plus)
  2. RedfordHenry | Aug 31, 2005 06:15am | #2
    Beware, all PVC trim is not the same.  I have found that different brands are manufactured at least two different ways.  My understanding (and I am not a PVC expert) is that some products are extruded as large sheets, then ripped by the manufacturer and sold in various dimensions.    The other method extrudes the trim boards individually (these usually have a slick finish and more rounded edges).   It has been my experience that the individually extruded products (e.g. Permatrim brand) have numerous, small, interior voids that look crappy when routed (or ripped).  Products that are extruded as sheets and then ripped (e.g. AZEK) are solid thoughout and is a much better product for routed edges.  The stuff pretty much routs about like pine but the chips are finer and stick to everything.  Also, any joints to be glued need to be dead flat and perfect for the glue to stick.  Good luck.
Mortar for Old Masonry
