pvc trim molding…is it paintable?
corvi1 | Posted in General Discussion on June 28, 2010 07:57am
I recently purchased some pvc trim molding to put around the wall/ceiling juncture. It is very white. The sales guy didn’t know if it was paintable or not. No biggie if it isn’t, but i’d like it to be a complementary color if possible and would paint it before installing it. I bought the trim at Lowe’s…it was item #2150… if there is anyone out there who works at lowe’s and knows the product. Looks easier to cut and install than wood trim and is said to be moisture resistant. It certainly doesn’t appear to have warpage issues and the room where it will be installed will have some degree of humidity.
  1. calvin | Jun 28, 2010 08:32pm | #1
    I looked and couldn't find it.
    Searched moulding-2150 and went through all the trims-didn't find a one called 2150
    I tried pvc moulding and got 3 for use with tile.
    Got a better description?  Is it that lightwt, cell filled plastic moulding from along time ago?
    Usually pvc trims can be painted.  Look at the azek site for finishing tips  http://www.azek.com/installation.html
    Best of luck.
  2. DaveRicheson | Jun 29, 2010 06:02am | #2
    We installed about 1000 lf of Azek molding in our enployee entrance hallway last year and had it all painted. So far we have had no problems with it.
    I'm not sure about Lowes pvc trim. It seems a little slicker than the Azek, so may need to be scuff sanded lightly to insure good adhesion.
    1. max512 | Jun 29, 2010 11:32am | #3
      Try Versatex blog
      Versatex has a great blog on painting PVC trim. They tell you what to look out for in terms of dark colors and expansion/ contraction.
      http://blog.versatex.com/Blog/?Tag=painting+pvc+trim
  3. Piffin | Jun 29, 2010 06:18pm | #4
    Just scuff it up a bit with 150-180 first to give it some mechanical "tooth" for the paint to bond with
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
