Pyramid Exterior Post Cap
smith | Posted in Construction Techniques on January 11, 2008 02:50am
I am trying to finalize my exterior newel post with a pyramid top similar to the one picture in:
http://www.taunton.com/finehomebuilding/PDF/Protected/021084060.pdf
My posts are about 9 in square at the top. I am having trouble deciding how to accomplish the pointed top with such a large cap (approx 12 in square). Do I miter 2 x similar to the one pictured and angle it down with the table saw? I am not really sure how to tackle this and feel it will be the most critical part of the final design.
My final desired cap would be a pointed top with about 1/2 – 1 in face and support crown moulding below the cap.
Any ideas will be greatly appreciated. Thanks!
  1. calvin | Jan 11, 2008 03:20pm | #1
    Smith,
    Only online subscribed members can view the link you provided.
    http://www.quittintime.com/
      JDRHI | Jan 11, 2008 05:33pm | #2
      Yeah.....I'd love to help the guy.....but I aint feelin'  THAT generous.
      J. D. ReynoldsHome Improvements
  2. Piffin | Jan 11, 2008 05:43pm | #3
    One option would be to buy them from Fypon.
    I don't know your design detailing because I can't see that photo, but one idea that comes to mind, it to make a jig for your planer to plane a bevel on a 2x8 or whatever, then cut four pieces at mitre to rejoin for each post cap. I have done that way for a pentagonal post or two.
  3. Piffin | Jan 11, 2008 05:46pm | #4
    http://www.islandpostcap.com/
    or try this outfit to see if they make them large enough for you
  4. MikeHennessy | Jan 11, 2008 05:50pm | #5
    Can't get to the post, but if I understand what you're asking . . .
    I'd cut it out of 12"X12"X2" stock. I'd cut as much of the pyramid as I could on the TS. Then I'd finish the top +/- 2" of the pyramid with a hand plane.
    Mike Hennessy
    Pittsburgh, PA
    1. Piffin | Jan 11, 2008 07:10pm | #6
      That is what I do with 8" ones, but these of his sound a lot larger.
      1. wane | Jan 11, 2008 07:33pm | #7
        band saw or handsaw ..
      2. MikeHennessy | Jan 11, 2008 07:36pm | #8
        "these of his sound a lot larger."
        Still, it's only the thin part that gets planed, so there's not much of it. 5 minutes would get the job done.
        And for someone who can plane down a couple of trees to get some beams, that tiny job would be no sweat! ;-)
        Mike HennessyPittsburgh, PA
        1. Piffin | Jan 11, 2008 08:19pm | #9
          Yeah, I know - but I can never tell what tools and skills somebody else might have when they need to ask about this sort of thing.Actually I bought a bandsaw two years ago, and keep forgetting that I have it - so how do I know if he has one?everybody has a plane though right?Or a belt sander....hundred ways to skin the cat according to what tools you have and what your comfort level with them.
    2. smith | Jan 13, 2008 05:08pm | #12
      Thank you for the response. I am finding out that the thickness is my biggest issue. But with all of the other posts about pre-made caps, I actually found pre-made cedar caps that I think will work. Thanks again for the insight.
  5. smith | Jan 12, 2008 12:25am | #10
    I am sorry for the PDF, wasn't thinking that early. Please let me know if you can see the attached JPEG. This is a smaller version of what I am trying to accomplish.
  6. Ragnar17 | Jan 13, 2008 11:47am | #11
    I don't know if your project is paint grade or stained.   But if painted, I would suggest you consider using something like Azek.  You can buy it in 3/4" thickness, and by cutting the proper angles, you could glue up your pyramid with four identical pieces.  The glue is very similar to PVC cement, so it results in a waterproof bond.
    I used a sheet of Azek to build some 20" wide wall caps and it has performed great.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
