Need some advice on how to fasten some quarter round trim to a brick wall. See attached pic.
I’m sorry, I thought you wanted it done the right way.
hey there,i would have to say pl premium or 5000 constuction adhesive is your best bet.
I agree on the PL, but it takes a long time to set up.
Ed,
In the past I have used PL with dabs of hot melt glue to hold things in place until the PL dries.Matt
yes it does take a while to set up, but as long as your brick wall dosent have any serious jogs or high spots in it you shouldnt have to worry about it pulling away from the wall as long as you apply the pl , stick it to the wall then pull it away off the wall and leave it sit for 5min then stick it back on you should be fine.you could always use certain household objects to put up against it to help it stay put if need be.
I've never tried the stick & pull away technique. Does that make it work more like contact cement?
ya a little,the air contact with the pl somehow reacts with eachother and makes it grab a little better.
Fasten the quarter round to the subfloor by toenailing. This is the correct way with any shoe molding regardless of the wall material.
mike
That could be difficult. The room used to be a screened porch, I raised the floor with 2x4 sleepers and 3/4 ply, so nailing at an angle will put the nails into the brick. If I can nail vertically, that might work.
If you were to drill for your nail hole at an angle greater than 90 you could nail into all wood - if you're willing to hand nail. That and maybe some flashing to protect the brick from scratches as you'd be so close to the wall.
3M marine adhesive
Had the same situation in my house. I used 5 minute epoxy mixed with glass beads to prevent the epoxy from running. Worked well - been down for 5 years - no problem.
I still use PL products during the framing and rough work phase, but now prefer LocTite PowerGrab for most finish work. Much higher intial tack and cleans up easily with water (should you get some on that nice new floor or your hands--of course the PL stuff will wear off your fingers in a week or so ; ). Shopvac the brick first though.
You really need to ask?
I am curious, do you?
"Sell your cleverness, Purchase Bewilderment"...Rumi
I don't really understand your message. I had thought of using PL or Liq Nails at first, but was wondering if I was missing something obvious. I don't really want to use PL cuz it will make removal very difficult in the future.
Sorry, I wuz being a wiseaxe...
I don't see why ya cant brad to the floor, let it float at the brick.
Yeah, but if the floor does move, then the gap opens at the brick.
I hear dat.
velcro...really easy to remove in the future..
velcro huh,i never heard of that before.what do you plan to do with the gap which would prob. be 1/2 inch or so between the wall and the quater round?i dont think you could just caulk the top of that and walk away,especially with brick.
use thinner velcro :)
After action report ...
I used hot glue and PL. Started by running a bead of PL on the back of the trim, discovered that wasn't the best idea cuz the trim only contacts the brick at the high spots, typically the joints. I applied a couple of globs of hot glue to the trim and press it into place. On the second piece I dropped it on the wood floor, PL and hot glue on the down side. After cleaning that mess, the next version was to put blobs of PL at the high spots, the carefully put a couple of blobs of hot glue about every 10-12 inches, and press into place.
Also discovered that it worked best with trim pieces not more than about 6 ft long, cuz that's as far as my arm stretch. The good part is that the bricks were cool enough that the hot glue set up pretty quickly, and I didn't have to stay "in position" for more than 30-45 seconds.
Shoot it into the briks with your Hilti. Use the RED power charges and 2 1/2" hardened pins. If they stick out a little, shoot it again with the Reds!
Send pictures after your done.
Lag bolts might work good too!
blueJust because you can, doesn't mean you should!
Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
The Loctite PowerGrab I mentioned has stronger intial tack than PL but is much easier to remove later, if need be. Try it sometime.Edit to add: I use it for toekick, cabinet end panels, crown molding, etc.
Edited 3/22/2005 11:13 am ET by basswood
nail it to the floor ...
next question please.
Buck Construction
Artistry in Carpentry
Pgh, PA
