Question about adhesive on slate roof
asingh0601 | Posted in General Discussion on April 5, 2021 10:55am
Hi all,
New poster here – I am the first to admit I am not a “handy” person. I recently entered into contract on a home with a slate roof, and was surprised to find multiple strips of (tar?) adhesive at the ridge along many tiles. The inspector stated that this was likely due to a prior leak, but couldn’t comment much more than that. Photos attached.
I am trying to understand: 1. What exactly the purpose of adhesive at the roof ridge is? 2. Whether I need to replace/repair this or do anything else? and 3. What the cost would be to do so?
Thank you all so much for your help!
  1. catmandeux | Apr 05, 2021 11:46am | #1
    There are slates missing, and it appears that the required copper or lead flashing was never installed. It needs reparing.
    How it should have been done: http://www.slateroofcentral.com/install_hips_ridges.htm
    http://www.traditionalroofing.com/TR8_ridge.html
    Slate is labor intensive, repair will not be cheap.
    If done right, it should last your lifetime without further maintenance.
  2. florida | Apr 05, 2021 12:21pm | #2
    I'll take a shot in the dark and guess that those are used slates, nothing wrong with that, that was done by the homeowner. Normally slate is oriented with the narrow dimension up. Yours are installed in landscape mode if you will. The ridges should have had a cap of copper or lead but it doesn't look like there was ever any there. I can't believe your inspector had no more to say about it. As cat said, it has to be repaired and I imagine other issues will come up once you have an expert on the roof. Make sure you hire someone who works with slate, not just a roofer.
  3. asingh0601 | Apr 05, 2021 12:56pm | #3
    Thanks for the replies guys. Obviously impossible to accurately estimate repair cost without seeing the roof itself, but any ballpark estimates (this is in Ohio)?
    unclemike42 | Apr 05, 2021 05:14pm | #4
    Figure out how many feet of peak you have and make a few calls.
  5. josh_s_5 | Apr 13, 2021 10:15am | #5
    I don’t think the roofing tar is necessarily the problem, but looks like they only fastened those slates on the ridge with a single nail, causing them to swing down. It’s difficult to tell from the pictures. My house was done similarly under architect supervision in the 30’s, though not quite as sloppy. I attached a picture to show how my roof looks. With that house, I would probably have someone come out to reposition those shingles closer together towards the peak with some overlap on top and fasten them properly...or price out a cooper cap. I wouldn’t think it would be terribly expensive either way.
  • A Postwar Comeback
  • Natural Simplicity
