Question about Ditra
mwgaines | Posted in General Discussion on September 14, 2010 09:49am
Why does Ditra have to be bonded to the floor? As I understand it, the purpose of Ditra is to uncouple the tile from the floor beneath it so each “layer” can move independently. If the sub-floor deflection is within acceptable limits, I don’t understand why cracks are more probable if the Ditra isn’t bonded to the floor.
  1. andybuildz | Sep 15, 2010 02:07pm | #1
    That waffle like texture is what gives it the cushion or..allows it to move w/o cracking  the tiles. It sort of absorbs the movement I think.
  2. semar | Oct 28, 2010 10:16pm | #2
    ditra
    ask Schluter who designed it
  3. Skoorb | Nov 03, 2010 02:13pm | #3
    If it's not bonded you could lift an entire install up by just pulling up on one end. It's still decoupling the install because even with the bottom part bonded and the top attached to the tiles, the way it shifts laterally allows them to move around without the bottom changing. Think about two pieces of plywood with a bunch of springs between them. The top can move around a bit to the side without the bottom moving at all due to the springs.
    I've done ditra only once. Listen when they say to go quite wet on that initial latex layer to the plywood/ditra connection. I went at the upper range of the latex mix and the install seems to be holding up fine, but you do want it quite wet to grab onto the bottom mat of the ditra properly.
