Questions about VS corded hammer drills
| Posted in Tools for Home Building on August 1, 2007 11:43am
I’m getting ready to buy a new corded hand drill. Considering a couple models: Milwaukee or Bosch variable speed hammer drills. with the 7-9 AMP rated motors.
Lowe’s has them on sale for $129-159.00, depending on the model.
Anyone have any experience with these or any advice to offer?
    MarkH | Aug 02, 2007 12:23am | #1
    Yes
    1. SGriess58 | Aug 02, 2007 02:51am | #3
      Yes...?
      Does that mean either one will do? Either one is fine? Or...?
        IMERC | Aug 02, 2007 03:34am | #4
        the Milwaukeel is better than the Bosch....
        either in pistol grip design are entry level and need to be treated kindly..
        MarkH | Aug 02, 2007 05:04am | #5
        I like my Milwaukee 1/2 magnum hammer drill.  They're great for making smaller size holes in concrete.  Not as good for other uses, I don't know what you have in mind.  I think either of them is a good unit.
        1. SGriess58 | Aug 02, 2007 09:58am | #6
          To: SGriess58 (6 of 6)
          93020.6 in reply to 93020.4
          I like my Milwaukee 1/2 magnum hammer drill. They're great for making smaller size holes in concrete. Not as good for other uses, I don't know what you have in mind. I think either of them is a good unit.Reply:
          Well, here's the deal: I didn't have a decent corded electric drill, and I don't have a hammer drill. I inherited a couple of old, all-metal drills from my dad, a Sunbeam Drillmaster (1/4" capacity, no idea of amperage), and the strongest one is an old 3-Amp Skil Drive-R-Drill (Mod.No.598) with a messed up Jacobs chuck that I can't get a replacement for.
          The other day I was trying to mix some mortar with the Skil, and it was shooting sparks and smoke out it's vent holes, and getting pretty warm to the touch. So I figured it was a wee bit underpowered, and since my DW was there to witness the carnage, it provided me with an object lesson in needing a new tool!
          So I went to the closest Home Improvement store and found a few that looked like they would be stronger: the Milwaukee hammer drill with the 7.5 amp motor and a couple of Bosch's with 8.0 and 8.5 amp motors (instead of the 3 amp I had), that might do the job. Then I thought maybe some folks in the Taunton forums might be able to give some advice.
          Since I have an old brick house, I occasionally have to drill through brick, concrete, plaster, etc. So the idea of getting a hammer drill appealed to my "two functions for the price of one tool" mindset.I ended up getting the Bosch 1199VSR, with the 8.5 Amp motor. Might have been a mistake, but I figured the extra power would help me get through this mortar-mixing and tiling project I'm in the midst of.
          If it tears up, fortunately the local H.I. store has a good return policy.
          If it survives, then I hope I'll have a fairly decent drill to use for a while.Thanks to those who submitted thoughts and opinions about this! I value the input of others who have experience with a variety of tools, and I look forward to participating in the various forum discussions.
          1. Jer | Aug 02, 2007 01:43pm | #7
            I have owned 2 Milwaukees and 1 Bosch hammer drills. The Milwaukees seemed to burn out long before their time but the Bosch is still going strong after 7 years. It's one of the few Bosch tools I've owned that is any good.
  2. JTC1 | Aug 02, 2007 12:35am | #2
    I have a Milwaukee, model 5378-02, 1/2", 6.5a corded hammer drill.
    Have had it for ~ 5 years - going strong.
    I only use this tool occasionally, and then just to punch a few holes for a lead anchor or some Tapcons.  Used probably weekly at most and then for a small job.
    Have used it with 5/8" and smaller bits in brick, block, tile and concrete.
    Biggest job I ever did with it was to bore about 40-50 - 3/8" holes through a concrete crawlspace floor to perforate the edge of a sump pump hole.  It did get a little warm doing that.
    I would not consider this tool to be a substitute for a regular 1/2" drill - wieghs too much and it is nose heavy.
    Jim
