Questions on stair railing in garage
Forrest | Posted in Construction Techniques on January 2, 2004 05:28am
I am building a 2 car garage with a loft in Maryland. It has a walk-up stairway. Do the same codes apply to a railing that goes to a storage space as a residential stairway? I would prefer to run two rails between the posts that build a railing with balusters for the garage.
Thanks,
  1. fdampier5 | Jan 02, 2004 07:11pm | #1
    Local codes are enforced differantly so while I hate to say this, it depends!
        The UBC allows non regulation railings to unoccupied spaces however..   thus you won't have to make the railings hold the 4inch test ball if your local offical accepts that..
      Some half informed home inspector might have a problem though and write it up should you ever decide to sell..
    1. CleetusJones | Jan 03, 2004 01:49am | #3
      I am unclear if the purpose of the 4" spacing is intended to keep Children from falling through, or so they don't get their heads stuck. If it is the head stuck scenario, then running 2 boards length wise should be OK. Seems like other railings featured in FHB use all kinds of  variations including cable and I'm sure I have seen some of these space greater than 4". Of coarse I could go look it up, but it is much easier to sit here and type away no matter how inaccurate I my be.
      1. archyII | Jan 03, 2004 02:48am | #4
        You just hit another snag.  The rail cannot form a ladder in most places (kind of defeats the purpose of a guardrail if the little ones can climb it).
      2. fdampier5 | Jan 03, 2004 04:55am | #5
        I'm fairly certain it's the head stuck issue.
        1. Piffin | Jan 03, 2004 07:10am | #6
          It is both. but more bodystuck than headstuck.
          Because there were some cases or it was speculated (not sure which now) where a child managed to get the body through but not the head.
          So you can envision a child's body dangling with the head still on the safe side and a strngulation or broken neck...
          It's prtetty much an attempt to apply Murphy's Law to stairrails.
          I agree, it is the local inspector who applies/interprets the rules. They don't generally apply to storage space in the same way as to living space..
            Forrest | Jan 03, 2004 04:37pm | #7
            Thanks to everyone for there responses.  I hate to bother my building officials and get on there radar. Most of the time they spend about 30 seconds looking at my stuff before they sign off. I am going to put up the handrail and a mid rail and be done with it.
            Thanks again,
  2. gdavis62 | Jan 02, 2004 10:12pm | #2
    I'm with Frenchy.  Don't ask us.  Ask your local building official.
