Any recommendations for a shop vac that is relatively quiet. All I have owned or heard
are about the same….very noisy. My hearing is somewhat shot, but I would like to buy one a lot quieter so my grandchildren’s hearing won’t be damaged when they are over.
fien...
WOW!!! What a Ride!
Fein or Festool.
They are loud on your wallet.
With the Fein, get and use their HEPA filter. Drywall dust w/out will ruin the motor and it'll howl almost as loud as the original ShopVac.
http://www.quittintime.com/
I love my Porter Cable. I'm not sure of the decible level. But drywall dust is no match for its bag and backup filter!You get out of life what you put into it......minus taxes.
Marv
Fein bar none - quieter than any 'household' vac.
Let's not confuse the issue with facts!
If the vac you've had has a port where you can attach your hose to make a blower out of it, you can find mufflers that attach. Those are noisy vacs.
Since then, the Shop-vac brand has redesigned their tops. You lose the blower capacity, but they're a lot quieter.
ALWAYS using a HEPA bag inside keeps the vac quiet. It seems the smallest amount of drywall dust will turn any vac into a screaming banshee.
Saying you're worried about your grandchildren suggests that this is for a workshop. Maybe it's time you added a remote vacuum, with dust ports around the shop.
If you have the cash, no doubt a Fein or Festool would be the way to go. The PC has also had its supporters, though I don't think as numerous as those for the Fein/Festool.
Me, I'm cheap. I found that the Ridgid WD1450 (with "Scroll Noise Reduction") I have is a nice middle of the road. It's a LOT quieter than my other Ridgid shop vac. That other Ridgid vac is on par with another I have (a Shop Vac QSP)... both of those are quite loud. Really loud actually. The WD1450 isn't super quiet, but it is a HUGE improvement over the others I have. And it's a lot cheaper than the Fein/Festool. All in all, I'd definitely buy another WD1450 if mine finally got tired.
Another vote for Shop-Vac having made real improvements. I bought a 12 gallon (cat. # 96112) this year being cheap and expecting a small jet engine with a lot less power but was pleasantly surprised that the noise isn't bad. It does normally run the exhaust air through some type of muffler but you can remove a plug to connect a hose to blow.
I think they have given up on the theory that they could make a vacuum motor unit infinitely small and thus cheap if they made it run infinitely fast and thus infinitely noisy.
I can also vouch for the Fein. Effective and very quiet. Not sure what they are going for now, but I thought the price I paid a few years ago was reasonable compared to similar vacs. Prices for the accessories are a little outlandish, though. One note: if you're looking for something more portable, look at either the Turbo I or Turbo II. I find the Turbo III's size makes it a little awkward to run up and down the stairs.
Utterguys used to sell reconditioned Fein Vaccums. I got my Turbo 1 from them and it was a bit cheaper. I think Fein is like Bose and requires all its retailers to sell its products for the same amount.
Fein and Festo are both good. I have used both, and currently own a Festo.
But the power and quietness of a Wap cannot be matched. My circa 1990 model is starting to fail -- it's almost as loud as a Fein now, but still beats it for suction.
For a power test, plug two vacs into a power strip, and couple their equal-length hoses together, with a ping-pong ball at the joint.
Now, with both vac switches in the ON position, turn on the power strip. Next, turn it off, open up the Wap, and remove the ping-pong ball.
'Nuff said.
AitchKay
Ditto everything about the Wap
http://www.alto-online.com/Products/VacuumCleaners/CommercialVacuumCleaners/CommercialVacs/SALTIX3/Introduction.aspx
bosch makes a good quiet one. traps concrete and drywall dust.
most dust collectors are a heck of a lot quiter than a shop vac Probably by a whole "bel", not a decibel.
Eroc
Fein is the quietest I've ever used. They're too expensive though. I got a little 8 gal Shop Vac and use a hepa filter along with a hepa bag. It's noisier than the Fein but very tolerable and easily does the same work for a third the price.
The Wap is quieter than the Fein, and it also makes the Fein seem inexpensive!AitchKay
Coastal Tool has the old style model Fein Turbo 1 on sale for $199. Looks like it's the same noise rating as the new ones.
http://www.coastaltool.com/a/fein/turbo-i.htm
