Has anyone had experience w/ this collated screw system?
Is it as rugged & reliable as billed? Recently built an 8′ x 16′ deck w/ composite decking, very hard to get screws (square drive composite screws) to set consistently.
Will this tool provide a means to drive screws uniformly in composite or other decking types? Model I’m looking at has Makita drill motor. Will it drive stainless steel screws reliably as well?
Thanks.
gd, welcome to Breaktime. You'll get used to this site. Here's some responses to your other posts on the same subject.
- from gdjc, 3/5/2007
- from gdjc, 3/8/2007
3. Quik Drive. Has anyone had experience w/ the Quik Drive collated ...
- from gdjc, 3/2/2007
You can keep track of your previous posts by going to the Show Discussions box up top/left side of the thread titles. Click on that box and hilight the High Importance (or something like that). That will bring up all the msgs you either chose as important, or posted to, or started.
In addition, there should be a place in your profile (or preferences) that you can check to be notified when someone posts to you. You can find out if there's msgs to you by clicking on My Forums in the yellow band up top-right side.
http://www.quittintime.com/
