R-15 vs R-13 ext. wall insulation
rez | Posted in Construction Techniques on October 15, 2002 07:05am
Some folks use fiberglass batts then cover the wall studs with foil backed foamboard before drywall. Taping the seams with foiltape completes the vaporbarrier so you cover an extra insulation value along with the vaporbarrier.
Half of good living is staying out of bad situations, the other half gets so complex I don’t deal with it.
I never had a problem with character, people have been telling me I was one ever since I was a kid.
  1. xMikeSmith | Oct 16, 2002 01:30am | #1
    when we were using fiberglass.. all we would use was the r-15, unfaced....... with a 6 mil. poly vapor / air retarder stapled over..
     the r-15 is a much tighter batt.. especially if you get the "Friction -fit".....  the normal r-13 with kraft or foil facing is real close to useless.. of the 2 , i'd absolutely use the r-15 friction fit unfaced batt..
    of course, nowadays i wouldn't use either.. i'd blow dens-pak cellulose instead
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
    1. maneyj | Oct 16, 2002 03:36am | #2
      Look around for a better price. I just did a house with R-15. Since it is special order most places, it is expensive. I got a national insulating co to install it for me for almost the same price I could buy it for. They keep it in stock.
        JDRHI | Oct 16, 2002 04:58am | #3
        OK, fill me in here. Unless there is a new product on the market Im unaware of, R11 batt insulation fits todays 2 x 4  (1 5/8" x 3 5/8") studs. R13 batt insulation is designed for older framing of actual 2 x 4 studs. What is R15 batt insulation and which size lumber is it designed for. Thanks in advance.J. D. Reynolds
        Home Improvements
        "DO IT RIGHT, DO IT ONCE"
        1. xMikeSmith | Oct 16, 2002 05:07am | #4
          they're all designed to fit in a 2x4 wall... the r-13 sucks... and the r-11 is below sucking.. the only one that comes close to filling the bay is the r-15
          but... ah , you no ...Mike Smith   Rhode Island : Design / Build / Repair / Restore
        2. maneyj | Oct 16, 2002 05:54am | #5
          As Mike Smith said, they all fit the 3-1/2" space. The R-15 is much denser then either the R-11 or R-13. R-11 is not even considered insulation anymore. It does not meet minimum code. It is classified as good for soundproofing, although I question that. R-15 is required in this area (SC)to qualify for the power company's good sense rate. As soon as the building supply yards start carrying R-15, the price will drop.
          1. wivell | Oct 16, 2002 04:21pm | #6
            How about the R-19 in 2x6 walls - does it fit well in your opinion?
          2. maneyj | Oct 16, 2002 07:20pm | #7
            Yes! R-19 fits snuggly in a 2x6 bay. If you want extra space for air, they make R-19C. This is a denser version of the R-19 that is made for cathedral ceilings.
          3. xMikeSmith | Oct 16, 2002 08:51pm | #8
            no.. in my opinion... R-19 does not fit well or snugly in a stud bay..especially if it's faced..
            if it's a friction fit batt, yes,  but still not in the same league as Dens-pak celluloseMike Smith   Rhode Island : Design / Build / Repair / Restore
