R-30 compressed into 7 1/4″
Jeff_Clarke | Posted in Energy, Heating & Insulation on October 10, 2008 09:05am
Attic floor:
Anyone see any problem, aside from some loss of R-value, with compressing 9 1/2″ R-30 batts into 2 x 8s – ceiling is 1/2″ non-sag gyp bd. and subfloor is 3/4″ sturd-i-floor t & g.
  1. MartinHolladay | Oct 10, 2008 12:03pm | #1
    Jeff,
    No problem.  The result will be a higher R-value than if you had purchased 7 1/4-inch-thick insulation (although slightly lower R-value than if your cavity measured 8 1/2 inches deep).
  2. frenchy | Oct 10, 2008 03:54pm | #2
    all you need is R 30 for the ceiling?  (well maybe a R20 or 25)  you must be pretty far south.. I have a full R50 and I wish I hadn't been talked out of my R80.  Energy is going to get a lot more expensive.  You can expect things to double within 7 years easily..
      Jeff_Clarke | Oct 10, 2008 04:33pm | #3
      All I have is 7 1/4" ;o)
  3. Clewless1 | Oct 10, 2008 04:41pm | #4
    Only if you are REQUIRED to install R-30 (e.g. by code). R30 crammed into 7+ inches doesn't meet code if R30 req'd. Otherwise, no problem ... other than increased heat loss/gain. If R30 is required ... look for an alternative. You have a sub floor above this? what is the space? Attic?
      Jeff_Clarke | Oct 10, 2008 04:43pm | #5
      Subfloor
      1. reinvent | Oct 10, 2008 04:51pm | #6
        Can you possibly afford spray foam?
        Would also eliminate convection losses.
