Racked Wall
| Posted in Construction Techniques on July 28, 2002 02:39am
I’m just about finished framing my new shop. And I have a question. I have a wall that is racked. And I’m working by myself. What is the bst way to square the wall up without any help. Thanks Hat
  1. FrankB89 | Jul 28, 2002 03:10am | #1
    Spanish windlass (twisted loop of good rope or wire) or a comealong with force exerted diagonally.  (I assume you haven't sheathed it yet).
    Edited 7/27/2002 9:40:13 PM ET by Notchman
  2. Piffin | Jul 28, 2002 06:07am | #2
    Springpole
    Drive stake in ground on end it is leaning towards.
    Run 1x8 diagonally from stake to top of wall lying flat ways
    Pull down in middle of board to bend/flex it
    It will grab the wall at top by friction as it slides down
    let it go to straighten up and it will spring back at the wall as it trys to straighten itself out, pushing the wall
    Conversely, if you want to pull a wall in, say to straighten it our in the middle.
    Nail the board to the floor and to the top of the middle of the wall (you are on the inside for this one.)
    Find the length from floor to board at about midpoint
    grab a two by about that length or a little longer
    wedge it in under the board and drive it tighter until it pulls the wall in enough. Friction should hold it while you check the level, then tack a nail at top and bottom of the two by to hold until trusses or ceiling joists are set.
  3. JCarroll38 | Jul 31, 2002 03:33pm | #3
    Hat, The springboard Piffin describes works great but it can be difficult to do solo. I use a couple of lengths of chain and a turnbuckle. There's a drawing of the basic set-up on p. 48 of my book, "Working Alone." The book is on the "By Pros, For Pros" book rack (located near the pro checkout counter) in most Home Depots. It's also carried by many Lowes. -John
    1. JCarroll38 | Jul 31, 2002 04:44pm | #4
      Here is the aforementioned drawing. You have to use this set-up on the end of the wall that is leaning out.
      Edited 7/31/2002 9:49:08 AM ET by John Carroll
A New Approach to Foundations
