Radial arm saw (What size wire????)
loucarabasi | Posted in General Discussion on December 19, 2007 11:51am
What size wire and breaker size do I use> Radial arm saw draws 9.6 amps and is 230 volt. My guess is 14 wire on a 15 amp circuit? Or should I beef up to 12wire on a 20 amp?
Thanks, Lou
  1. bubbajames | Dec 19, 2007 03:24pm | #1
    Any workshop circuits I would recomend 20 Amps to allow for down the road expansion. What if you added a dust collection system down the road?
  2. JTC1 | Dec 19, 2007 04:37pm | #2
    I would use #12 and a 20A breaker - unless the saw manufacturer objects to the 20A breaker - then I would use #12 and a 15A breaker.
    I have never seen a power tool which did not like an ample supply of voltage.
    9.6 amps = loading a 15A to 64% of capacity, 20A only 48%.
    Ample volts / amps will help your saw start easier, cut stronger and live longer.
    Jim
A New Approach to Foundations
