Radiant floor heat and mud jobs
KeithJMazz | Posted in General Discussion on July 1, 2008 04:46am
My plumber is installing radiant heat with 1/2″ Pex for the bath floor. The existing sub floor is 1×4 square edge with spaces between. Should I remove the majority of the floor and install 3/4″ ply? How thick should the mud be? I am concerned with mud and tile cracking as the heat expands the work. My jobs are usually 3/4″ to 1″ above the wire. Should the Pex come in contact with the wire?
  1. rez | Jul 05, 2008 10:17pm | #1
    Greetings Keith,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
  2. rez | Jul 13, 2008 04:40pm | #2
    let's run this thru again.
    Click here for access to the Woodshed Tavern
    Click here to visit the beginning of Breaktime
  3. inperfectionist | Jul 13, 2008 11:23pm | #3
    Keith,
    You might want to try this question over at John Bridges Tile Forum.
    How big is your bath?? Is there a tile shower? Is the radiant also going in the shower? How much hieght increase can you afford? What story of the house are you working on? Can you insulate the floor?
    I have done several similar installs,,,,, they are pretty common.
    Provide a little more info and you'll get a better answer either here or over at Bridges.
    Best of luck, H
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
