Once again seeking knowledge…. Has anyone used a tankless water heater to heat water for radiant heat? It seems like this should work well, and AquaStar has one that they label for an open loop system, but I’d like to know if anyone has actually installed one-
Background- northern Michigan, fuel is LP, heating 2300 sf, including garage, single floor only for this application. Thanks for your help- Cami
Get a closer look at the building process for this durable, flush, lightweight door.
Once again seeking knowledge.... Has anyone used a tankless water heater to heat water for radiant heat? It seems like this should work well, and AquaStar has one that they label for an open loop system, but I'd like to know if anyone has actually installed one-
