Radiant floor options
cwc09 | Posted in General Discussion on September 2, 2009 11:57am
I am finally going to tear up the carpet in my room and lay some hardwoods. I am thinking of installing some radiant heating as well. My room is located over a garage and the floor is insulated but I worry that it will be too cold in the winter.
1. Any recommendations for a radiant flooring product?
2. If I install the radiant heating above the subfloor does this rule out nail down hardwoods? (bring on the jokes)
3. I do have the option of tearing down the sheetrock garage ceiling below my floor to install underneath the subfloor but this is a lot of extra work. However it would allow me to have much less of a floor height change from the bedroom to hallway. Any thoughts?
Thanks for any feedback
  1. MikeSmith | Sep 02, 2009 01:28pm | #1
    you can do Quicktrack and then do an engineered hardwood glue down like Mannington
    or nail your hardwood floor down and THEN  take down the garage ceiling and install a staple-up   tubing system below
  2. GRCourter | Sep 02, 2009 03:32pm | #2
    Use the Quicktrac system, put your rosin paper down and trace the tubing with spray paint and just don't nail the spray paint.
  3. Sbds | Sep 02, 2009 05:13pm | #3
    What kind of heating are you planing on using. Electric or hedonic?
    1. TomW | Sep 02, 2009 05:18pm | #4
      Hedonic??Is that what they use down in Jamaica at those adult resorts?? Sounds like fun but I don't think his wife will go for it:)
      1. Sbds | Sep 02, 2009 05:33pm | #5
        That's what I get for looking at BT at work. Typing and talking on the phone and looking at files at the same time does not work. Lets try this again. Electric or hydronic?
        1. cwc09 | Sep 04, 2009 11:38am | #6
          I really havent decided between electric and hydronic. This has been the first step in my reseacrh of the product. What are the pros and cons for each?
            Beachton | Sep 04, 2009 07:18pm | #7
            Well have you got a source of hot water? I'd think that would be the deciding factor. I've used the Suntouch electric radiant heat under tile bathroom floors two times with good results. http://www.suntouch.com/ I just ordered it online, with the programmable thermostat. http://www.warmyourfloor.com/This last time used it I put reflective bubble wrap style insulation under the subfloor since it was exposed to outdoor air. Personally I'm terribly allergic to any solvent based glue so I would only use the kind of floor that uses an ordinary white glue.According to the website you can pour a 1/2" thick self-leveling mortar base over the wire mats and put down engineered flooring.You can also use nailed down flooring and put the heating elements under the subfloor from the other side.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
