Radiant heat sources for a garage shop
| Posted in General Discussion on January 11, 1999 12:56pm
I’m looking for information on gas or
electric powered radiant heat systems. I
have a 24′ x 30′ space and would prefer
a system that could be mounted to the
ceiling so as not to take up floor
space. Any info would be helpful…..
  1. John_Dennis | Jan 09, 1999 01:58am | #1
    I'm looking for any info on the pro's and con's of
    using ceiling mounted radiant heat in a 24' x 30'
    garage shop. Company names that could supply a
    system would also be helpful. Thanks, J.
    1. Marty_R | Jan 10, 1999 10:21am | #2
      *Hi John Go to http://www.sshcinc.com. These guys are good. Ask for the factory seconds, theyre much cheaper.Good luck
      1. WNelms | Jan 11, 1999 12:55am | #3
        *John - - one of the most effective radiant systems is natural gas (or Propane) low intensity infrared heating appliances. These systems mount to the ceiling and operate at a much lower temperatures than the red hot high intensity spot heaters. They tend to be much more comfortable, especially if you have a higher ceiling. The hot tube radiates heat to the people and other objects in the room which, in turn, convect heat to the air. You'll see these systems in mechanics shops, like Midas Muffler and such, and the mechanics love them. If your shop has ceilings 16 to 24 feet tall, these systems will not cause the severe temperature stratification caused by forced air furnaces. I've installed these systems in several locations with no problems. One air plane hanger had 45' tall ceilings and there was but 5 degrees Fahrenheit temperature rise from the floor to the ceiling. Some manufacturers are Co-Ray-Vac, ReVerbaRay, Space Ray and there may be others. A link for one manufacturer is as follows:http://www.spaceray.thomasregister.com/olc/spaceray/infrared.htmGood Luck
        1. mikemeire | Sep 18, 2018 05:42pm | #5
          infrared heater choices
          Get a full range of choices from many manufacturers
          https://www.iqsdirectory.com/infrared-heaters/
  2. John_Dennis | Jan 11, 1999 12:56am | #4
    I'm looking for information on gas or
    have a 24' x 30' space and would prefer
    space. Any info would be helpful.....
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
