Rafter/Joists nailing schedule.
blownonfuel | Posted in Construction Techniques on September 10, 2008 07:27am
What is the nailing schedule for rafter to joist, joist to top plate, rafter to top plate?
Also how much should joists overlap at the lap and what is the nailing shedule?
  1. blownonfuel | Sep 11, 2008 04:34am | #1
    Bump.
  2. Jim_Allen | Sep 11, 2008 05:21am | #2
    bump
  3. dovetail97128 | Sep 11, 2008 07:47am | #3
    These are minimum
    ceiling joists to plate-3 8d.toe nails
    ceiling joists at laps 3-10d
    ceiling joists to parallel rafter 3-10d
    joists to rim joists 3-16d
    rafter to plate 2-16d toe nails
    Laps for joists IIRC are a minimum of 3", however that depends on whether they are being used to resist rafter thrust . I prefer on the order of 1' myself and always over nail them .
    1. dovetail97128 | Sep 11, 2008 07:53am | #4
      These may not be current code so don't take my word alone on this. Been awhile since I actually had to deal with it.
      1. blownonfuel | Sep 11, 2008 03:33pm | #6
        Thanks Dt.
        1. dovetail97128 | Sep 11, 2008 05:53pm | #9
          FWIW
          The info I listed came directly out of an old code book I had handy.
          It was CABO, table 602.3a
    BossHog | Sep 11, 2008 02:06pm | #5
    It would vary depending on the span and pitch of the rafters.
    Shorter spans and higher pitches would require fewer nails. Longer spans and lower pitches would require more nails.
    IMHO this is one of the downfalls of stick framing - No one ever bothers to check this stuff. They just keep building things the way they've always done it.
    History teaches us that man learns nothing from history [Hegel]
    hammer1 | Sep 11, 2008 04:30pm | #7
    We use 16d nails for framing. Three toe nailed into the plate, two on one side, one on the other. Joists are nipped on the top to match the rafter pitch, they sit completely on the plate. Two toe nails into the plate, three or four straight through the rafter, depending on size and overlap. Some high wind, seismic areas require metal straps or connectors in addition to the nails. 8d toe nails would not be acceptable for rafters or joists. Local codes vary.
    1. blownonfuel | Sep 11, 2008 05:02pm | #8
      Thanks H. So 3 16ds into joist, 2 16ds into rafter, then 3-4 16ds into both joist and rafter.
        hammer1 | Sep 11, 2008 05:59pm | #10
        That's typically how we do it. With a 16d toe nail you can get a pretty good grab through a lot of meat. Placement of the nails should receive careful attention. You want to stay back from ends and edges so the wood doesn't split, avoid knots and watch wild grain. No sense adding extra nails if they will cause something to split. Two solid toe nails into a top plate is better than three that split the end.Beat it to fit / Paint it to match
        1. blownonfuel | Sep 11, 2008 06:10pm | #11
          Thanks Hammer.
