Rafter tail decorative cuts
| Posted in Construction Techniques on April 12, 2004 05:05am
Looking for ideas to cut rafter tails for a pergola.  Looking for a ranch or southwestern idea.
Whenever you are asked if you can do a job, tell’em “Certainly, I can!”  Then get busy and find out how to do it.  T. Roosevelt
  1. MarkCadioli | Apr 12, 2004 06:01am | #1
    Ed
    FHB showed a horsehead detail some time back...quite neat
    regards
    mark
     Quittintime
    BillHartmann | Apr 12, 2004 05:18pm | #2
    "Looking for a ranch or southwestern idea."
    Are you looking for Design ideas or methods of doing it.
    For a SW look I would think about a straight edge, zip-zag "lighting bolt" design. And that would be much easier to do than the more typical S or double S curves.
    But I might also pierce the beam with a 1 or maybe 3 diamond cutouts.
    1. FastEddie1 | Apr 13, 2004 05:46am | #3
      I was looking for design ideas.  There's going to be about 65-70 tails to cut, so I may be back looking for method ideas.  My first thought is a luan template for a bearing guided router...roughed out first with a jig saw.
      Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
      1. Novy | Apr 13, 2004 06:51am | #4
        Try a little research on the green & green cloud drops......On a hill by the harbour
        BillHartmann | Apr 13, 2004 06:54am | #5
        My idea is all straight cuts so you you don't need to do any finish after the jig saw.
        I guess diamond cutouts I would drill a big hole and then cut it with a jig saw.
        However personally I would do adifferent pattern. I would use a double S curve, "cloud lift" pattern and round over the edges. I would also round over the end all of the cross pieces.
        That is inspired by Greene and Greene. But I don't think of that as being SW.
        I have attached a picture of mantle that I did with G&G styles corbels.
A New Approach to Foundations
