When you guys frame a cathedral ceiling with a “ridge beam”, do you like hanging your rafters from the side or placing them on top of the beam? Any way better than the other?
![](https://images.finehomebuilding.com/app/uploads/2024/08/15131650/FHB-645-Pod-Feature-thumb-16x9.jpg)
Listeners write in about condensing dryers, giant gears, and saggy doors and ask questions about chimney safety, black windows, and rot-resistant assemblies.
Greetings rakuz,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Peach full,
easy feelin'.
First choice when possible, notch them on top of the beam. Eliminates the need for a metal hanger, which it should have if the ridge beam is installed flush.
More often than not the design calls for a flush beam though with cathedral ceilings.
I prefer to drop the beam, then lap the tops and nail them together securely.
I've done both. Although prefer the side mounted rafters method myself.
