Railings fabricated from Azek?
Kirk | Posted in General Discussion on July 15, 2008 07:27am
Has anyone tried to fabricate railings out of Azek reinforced with aluminum channel? I’m finishing up my front porch and was considering this, since I used Azek for the trim and to wrap the posts. Here is a ruff sketch of what I came up with. Is it worth trying or should I go with a standard railing system?
Thanks in advance for your response.
    McDesign | Jul 15, 2008 07:29pm | #1
    Looks interesting!  I would probably go with something like 2x2 or 2x3x.125" rectangular tubing for extre stiffness.
  2. john7g | Jul 15, 2008 08:54pm | #2
    how stiff is that AL channel?  Those Cs deflect quite quite a bit unless supported often and close together. The problem is focused on the bottom rail C-channel only though.  The balusters will support the upper rail.
    I'd also experiment with the different growth rates of the 2 materials bolted together in high heat and the cold you'd expect for your locale.
    1. CableRigger | Jul 15, 2008 09:49pm | #3
      My first thought was along those lines also. While composite decking certainly grows in length a substantial amount when warmed, I'm pretty sure Azek doesn't, otherwise it wouldn't be a very good trim material.
      As far as the aluminum channel, 1/4" thick would probably be a good thickness, although pretty expensive. The Azek (if you decide to use it) would only add stiffness if fastened well. The aluminum itself would be the most stable thing in your assembly.
      How were you thinking of attaching the Azek to the aluminum, and how were you going to attach the aluminum to the posts?
      1. runnerguy | Jul 16, 2008 12:58am | #4
        Azek does contract and expand with the temp.
        As a matter of fact, so much so that Azek recommends not painting their product with a dark color which would only increase heat absorbtion and thus expansion.
        Runnerguy
        1. Pelipeth | Jul 16, 2008 01:08pm | #6
          I believe Sherwin-Williams makes a paint now (dark colors) that can be used on AZEK, check with the AZEK rep.
          1. ChicagoMike | Jul 16, 2008 01:16pm | #8
            Wouldn't the AZEK spindles bend and warp? Azek is pretty floppy unless supported.
            "It is what it is."
          2. MikeSmith | Jul 16, 2008 01:24pm | #9
            Azek makes a deck product.... I d be surprised if they don't make a railing system toowhy reinvent the wheel ?Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            jonblakemore | Jul 16, 2008 05:10pm | #10
            Azek does make a rail section.View Image
  3. rnsykes | Jul 16, 2008 07:39am | #5
    yes! Did one exactly like that at my brother in law's house. We used 1 1/2" track from depot to make it stiff. The short sections were solid. The 12' long section.... Not so much. It'll keep our kids from falling off the porch, but I wouldn't stand on it. Worked out well, and no problems with expansion/contraction so far. He actually has used the exact same design for two other clients and hasn't had a problem yet. We cut a separate beveled piece for the top to shed water, and to hide the screw heads we used to attach the railing to the painted wood spindles. We glued that top piece on using the azek adhesive. He thinks he was the first one to come up with the design....
  4. Pelipeth | Jul 16, 2008 01:13pm | #7
    I love the stuff, but my feeling is that any time you cut the stuff the (end/edge) grain is not smooth ie. factory finish, this gets dirty REAL quick.
  5. Whitewood_Millwork | Mar 22, 2021 12:48pm | #11
    We successfully use aluminum to stiffen Azek railings all the time. We use either 1/4" bar stock or rectangular tube, depending on the application. A two part structural adhesive (Chem-Set Trim Grip) bonds the aluminum to the Azek.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
