railroad tie retaining wall
BillWemyss | Posted in Construction Techniques on May 23, 2004 12:07pm
I`m building a 4 ft high retaining wall out of old railroad ties.Its rough on my chain-saw blade.Can you clean it?I`ve been pegging it with rebar.Basically this is a nasty job and any helpful hints would be appreciated.
  1. Ruby | May 23, 2004 12:12am | #1
    For railroad ties, telephone poles, etc full of creosote, I use a long wood blade on the Sawzall. Works better and longer than a chain saw and it doesn't kick back on the tough center veins.
    1. BillWemyss | May 23, 2004 01:34am | #2
      I`ll try the sawsall.Does the creosote gum up the blade?If so can you clean it?
        SamT | May 23, 2004 02:51am | #3
        Try mineral spirits to clean creosote tar.
        Samt
        Arguing with a Breaktimer is like mud-wrestling a pig -- Sooner or later you find out the pig loves it. Andy Engel
    dieselpig | May 23, 2004 04:23am | #4
    43583.1
    No way I'm cleaning someone else's chainsaw!  But if you want to do it yourself you can try Gumout along with the pre-mentioned mineral spirits.  I believe I also have a can of spray that is actually called "Pitch and Gum Remover" that is meant to be used for cleaning saw blades.  If you ask me, it's just oven-cleaner in a different can though!
  3. junkhound | May 23, 2004 05:44am | #5
    Hose it off sideways from a 45 degree angle or more, that will help the CS blade. Also compressed air works at very oblique angle(>80 deg).
    Of course, if you hit a spike, get a new chain.
    Probably have done over a hundred RR tie cuts with old cross cut saw in the 50's. Even (especially) with a hand saw always washed them first. When RR right of ways were first being abandonded, think that was where RR tie landscaping started. A Mr. McAllister, a friend of Pops, lived next to an Illinois Terminal line being abandoned in the 50's, had about 2000 ties in his yard as he could not pass up a good deal as he said he got paid 10 cents apiece when he was a kid to cut down an oak and make a tie.
Fast, Accurate Wall Framing
