Railroad Ties
mkbug | Posted in General Discussion on August 9, 2002 08:30am
I’m doing some restoration work on a cattle corral on a National Park. The posts are made of railroad ties. I need to know the best way to cut them. We’ve tried a chainsaw and the sand in the ties just dull the chain. We have been handsawing them for now. I’m going to try my Skill…what are your thoughts on a blade?
Peace,
Martin
  1. MarkH128 | Aug 09, 2002 01:56pm | #1
    Carbide chainsaw chains? http://www.hev.com/carbichain/carbichain.html
    Or maybe a large enough circular saw with a carbide blade would work better.
  2. PhillGiles | Aug 09, 2002 05:27pm | #2
    As old-fashioned as it sounds, a descent bow-saw cuts ties as well as anything.
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  3. TomT226 | Aug 09, 2002 07:54pm | #3
    Rent a post puller. You ought to be able to get the chain around the tie. There are two types. The jack type and tractor mounted.
      BossHog | Aug 09, 2002 11:35pm | #4
      How did we get from cutting ties to pulling them?
      Everything should be made as simple as possible, but no simpler.
  4. ToolDoc | Aug 10, 2002 07:15am | #5
    Martin: Try a sawzall with a long blade it will buzz right thru em.. alot cheaper than
    buying a carbide saw loop for your chain saw..
    Good luck.. ToolDoc
    1. mkbug | Aug 11, 2002 09:00pm | #6
      ToolDoc,
      I think you're on to sumthang with that...
      Thanks,
      Martin
      1. ToolDoc | Aug 11, 2002 09:43pm | #7
        Martin: Yes I have had to cut railroad ties for cribbing and for use as steps in
        landscaping and I first tried cutting them with a chainsaw with very poor results
        then i thought of using my sawzall with a long wood cutting blade it just buzzed
        right thru they worked like a charm for me..
        good luck...ToolDoc
  5. Catskinner | Aug 12, 2002 12:11am | #8
    We just did a retaining wall with ties, and after hearing the ideas I'd tried (mentioned above) my crew decided to try cutting all 4 sides with a regular carbide blade in a circ saw to get a clean cut all the way around, then taking the remaining material in the center of the tie with the sawzall.
    It worked faster, cheaper, cleaner, and better than anything I'd ever seen. I ought to leave these guys unsupervised more often. <G>
    DRC
  • Smarter Stop Block
