Rainwater filter?
JohnT8 | Posted in Construction Techniques on June 12, 2008 11:26am
Just curious about some fresh ideas on how to filter rainwater prior to it going into a cistern.
Seems like the old filter boxes had gravel, sand,and some kind of fabric that the gutters would dump into.  And then after it sifted through the gravel, sand, fabric, it would drain into the cistern.
Anyone have info on this stuff?
“If we don’t put effort into creating what we want, we must then put effort into coping with what we have.” –EPNIA
  1. timkline | Jun 13, 2008 01:37am | #1
    http://www.conservationtechnology.com/downloads/RainwaterSystems.pdf
    carpenter in transition
    Dinosaur | Jun 13, 2008 03:28am | #2
    I remember reading an article about a 'roof-washer' system for recuperating rainwater...but I don't remember where I read it. It may  have been in FHB; but this was many, many moons ago.
    I believe the term was 'roof-washer'....
    Yup, it was:
    Roof Washer | Rainwater Harvesting Guide
    A roof washer is a device or even simply a method for removal of sediment and debris from collection surfaces shortly after the rain has started to fall.
    http://www.rain-barrel.net/roof-washer.html - 10k - Cached - Similar pages
    Rainwater Harvesting and Purification System
    To avoid long lengths of roofwasher pipe, it makes sense to use larger diameters. ... Update January 2004 -- An American-made roof washer and rainwater ...
    ersson.sustainabilitylane.com/rainwatr.htm - 15k - Cached - Similar pages
    Roof washer
    My recommendation at this time is to employ a homemade Texas style standpipe roof washer. Its simplicity allows it to be constructed and maintained ...
    http://www.earthplatform.com/roof/washer - 13k - Cached - Similar pages
    Dinosaur
    foolish men call Justice....
    1. JohnT8 | Jun 13, 2008 04:46pm | #5
      I've read a few articles on the roof washer method.  People seem to have mixed reactions about them.
      The basic ones which are little more than a bucket that holds the first 3-10 gallons of water and then let it leak off over time... In theory the first few gallons of rain wash the roof off and thereby you get the cleaner water in your cistern.  But the down side is that when the drain that lets the water seep out clogs..you can get nasty stuff growing in your rainwater filter.
      There are more advanced ones, some of which involve electronics, but seems like they have very mixed reviews, especially in a mixed climate of below freezing in winter and very hot in summer.
      "If we don't put effort into creating what we want, we must then put effort into coping with what we have." --EPNIA
  3. JimB | Jun 13, 2008 03:33am | #3
    Here are two more links.  The first is a company that sells rainwater collection systems, the second is good info on general principles of rainwater collection.
    http://www.rainwatermanagement.com/
    http://www.cabellbrandcenter.org/CB%20Center%20webpage%20Current%20Projects.html
  4. Danno | Jun 13, 2008 03:56am | #4
    I tried to use the link posted by timkline and it froze, so I couldn't see what it said, but I would think landscape fabric would keep the sand in the filter. I suppose activated charcoal wouldn't hurt. I suppose the web sites address all that. There are lagoon sytems too that use reeds and cattails and such to filter the water.
    1. JohnT8 | Jun 13, 2008 04:48pm | #6
      attached it.
      1. JohnT8 | Jun 13, 2008 04:48pm | #7
        Thanks to all for your info and links.  I will read through them.
  5. mrsludge | Jun 13, 2008 09:09pm | #8
    I have 2 rain barrels on downspouts. I ended up getting some inexpensive stainless colanders from a restaurant supply store. They're round and have lots of 2.5mm holes.  Seems to be a good balance between not getting overwhelmed by the flow and filtration. The top of each barrel has a cutout that the colander sits down in.
    At one point, I had visions of a 275-gal tote or more manifolded barrels in the back of the yard for longer term storage. My thought was to make essentially a slow sand filter for the feed.  That'd be a 10-12 gallon bucket with PVC manifold w/ lots of small holes in the underside, bedded in gravel, with 1'0" or so of sand on top. The idea would be to pump from the barrel into the filter bucket, which would drain into the bigger storage by gravity. Scrape off the top sand when it gets gunky.
    The barrels by themselves have worked fine, though. Water gets a touch anaerobic and slightly stinky after a few weeks. But we just made it through a couple weeks w/o rain and 100F temps and managed to get the garden started w/o running out.
