Raising a balloon framed house
alcharbonneau | Posted in Construction Techniques on January 6, 2009 12:05pm
I have a single story 30×34 house at the ocean which was built 50+ years ago.  When I purchased the house 30 years ago, the foundation, which is down about 21″, showed some evidence in one corner of prior frost heaving.  It has been stable since I have owned the house.
My question is: does a balloon framed house present any more of a problem with respect to foundation repairs and/or replacement?
I am asking so that I can be more informed as I explore options with contractors.
  1. ruffmike | Jan 06, 2009 12:23am | #1
    I own a balloon framed house that was lifted 5 ft so a lower floor could be added.
    I don't think it matters, especially to a house mover.
                                Mike
        Small wheel turn by the fire and rod, big wheel turn by the grace of god.
    1. alcharbonneau | Jan 06, 2009 12:28am | #2
      thanks
  2. Dogmeat12 | Jan 06, 2009 12:36am | #3
    If it is a one story house how can it be "balloon framed"? Also, I've only done one building job (an addition)at the Ocean and if I remember correctly the frost line was only 12" as opposed to 32" further inland. Are you sure it was frost heave that caused the damage?
      jonblakemore | Jan 06, 2009 12:44am | #4
      True balloon framing means the studs go down to the foundation mudsill.
      1. Dogmeat12 | Jan 06, 2009 12:56am | #6
        Interesting. I always think of balloon framing as sixteen foot wall studs.
        1. Riversong | Jan 06, 2009 01:44am | #7
          Balloon framing builds the walls on the sills and then laps the first floor joists next to the studs, setting the second floor joists (if 2 stories) and ceiling joists on let-in ledgers. It also typically uses let-in 1x4 diagonal bracing in the walls and rough-sawn sheathing, roof decking and subfloors.
          Riversong HouseWright
          Design *  * Build *  * Renovate *  * ConsultSolar & Super-Insulated Healthy Homes
          1. Piffin | Jan 06, 2009 02:23am | #11
            "It also typically uses let-in 1x4 diagonal bracing in the walls and rough-sawn sheathing, roof decking and subfloors."Possibly so in your limited experience. I've seen balloon frames with all sorts of bracing and sheathing details. What you think of as typical - ain't that often
          2. Riversong | Jan 06, 2009 02:45am | #12
            My experience may be limited (as is yours no doubt), but my knowledge is extensive and thorough.
            What I described is the classic balloon framing system developed in Chicago in the 1830s and commonly used throughout the US until the 1950s.
            Just like with Western platform framing, there are as many variations as there are carpenters, and I've seen plenty. In fact, I'm one of the few modern builders who uses a hybrid of platform and balloon techniques.
            Edited 1/5/2009 6:46 pm ET by Riversong
          3. rez | Jan 06, 2009 05:05am | #13
            snorK*
          4. dovetail97128 | Jan 06, 2009 09:27am | #18
            FWIW Balloon frames often had blocked diagonal bracing or quite often none at all as the sheathing was applied diagonally and diagonal bracing wasn't even a requirement then. Let in braces were perhaps the norm , but I have seen ledgers nailed to the studs and joists toe nailed to the ledgers as well.
          5. Snort | Jan 07, 2009 02:45am | #26
            I used to recycle houses in Virginia. I never saw a balloon frame with let in diagonal bracing. I only saw one with a let in 2nd floor ledger, and that was covered with crown. Lot of rough sawn wall/roof sheathing, but not all, some even t&G. Same with subflooring, if they even had it <G>http://www.tvwsolar.com
            I went down to the lobby
            To make a small call out.
            A pretty dancing girl was there,
            And she began to shout,
            "Go on back to see the gypsy.
            He can move you from the rear,
            Drive you from your fear,
            Bring you through the mirror.
            He did it in Las Vegas,
            And he can do it here."
          6. Dogmeat12 | Jan 06, 2009 04:34pm | #21
            Exactly, execpt in this neck of the woods I've only seen that on two story houses, not single story. It may be a regional thing.
    2. alcharbonneau | Jan 06, 2009 12:50am | #5
      I called it balloon framed because the wall studs sit on the sill plat as opposed to the subfloor which would be platform framed.
      I verified the depth of the foundation via inspection.
  3. Riversong | Jan 06, 2009 01:46am | #8
    Yes it does. An entire house can be lifted by jacking the 1st floor deck of platform framed. If balloon framed, a ledger needs to lagged to the outside of the exterior wall studs so that the frame can be jacked up off it's foundation. Often the bottom of the studs are rotted and need to be patched and sistered, preferably with PT wood.
    1. alcharbonneau | Jan 06, 2009 02:06am | #9
      thanks - that will be helpful
  4. Piffin | Jan 06, 2009 02:21am | #10
    Depends on the type of sills and their condition, i.e. how much rot or termite damage....How large they were originally.
  5. davidmeiland | Jan 06, 2009 05:19am | #14
    How long are the studs *below* the bottom of the floor joists? I suspect a house mover is going to want to lag ledgers onto the studs, and still have room to insert their steel beams.
    1. alcharbonneau | Jan 06, 2009 05:47am | #15
      If I understand your question, the answer is that the studs are sitting on the sill plate, nailed to the plate and the floor joist.
      1. davidmeiland | Jan 06, 2009 07:22am | #17
        So the bottoms of the studs AND the floor joists are both sitting on the mudsill?
        1. alcharbonneau | Jan 06, 2009 03:47pm | #20
          yes - if what you call the mud sill is the same as the sill plate.
          1. robinpillars | Jan 06, 2009 05:00pm | #22
            We've lifted six balloon framed buildings over the last three years and several others before that. It isn't a lot harder than typical, but does require some care. As others have suggested adding a ledger to lift off of is a good way to go. In multi story buildings interior bearing walls can be used or built and the second story floor ledger can be used instead. The structure of the sheathing is also typically significant. On the building we are working on now (about 3500 SF commercial 2 stories w/ 14 ft. ceilings) we calced. it out and the sheathing alone would have carried the 12 times the jacking load. We ended up using LVL ledgers lagged w/ ledgerlock screws to lift though.Rob
          2. alcharbonneau | Jan 06, 2009 05:12pm | #23
            Thank you.  This is a one story house with an undeveloped attic.  The "sheeting" is traditional horizontal boards rather than plywood.
            Why are you raising houses - to move, replace foundations, add basement?
            Al Charbonneau
          3. robinpillars | Jan 07, 2009 12:21am | #24
            Typical here is full 1x (4/4) sheeting in a variety of widths from 4"-10" widths. Our calcs. were that 1x4 sheathing 4' high with 1 nail per board per stud would carry our jacking load. We have jacked them for all of the reasons above. Although replacing foundations is a relative term as piled rocks are the closest thing to a foundation we have had to work with. Typically we have to replace quite a bit of rotten stud too (6"-18" is typical). Recently we have been adding full basements as 40" deep foundations are required here for frost, and from that point it is relatively easy and cheap to gain the SF a basement adds.Rob
            Edited 1/6/2009 4:22 pm by robinpillars
          4. alcharbonneau | Jan 07, 2009 12:48am | #25
            Interesting.  My project involves potentially replacing a crawl space foundation with another crawl space.  The house is located at the ocean so we don't want to go too deep because it usually means either a damp basement or water.  I have crawled the entire space with an engineer- the sill plate and wall studs are solid which suprised everyone.
            Also, the project will most likely end up replacing the sheeting which, because of code specs for wind shear, will require a nailing pattern similar, I think, to the one you described.
            Nice chating with you.
  6. DanH | Jan 06, 2009 06:26am | #16
    Don't know why no one has stated the obvious: To lift a balloon frame you just fill it with helium.
    The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one. --Wilhelm Stekel
    1. Riversong | Jan 06, 2009 10:33am | #19
      Then, if your building doesn't lift, at least everyone will get a rise out of talking like Donald Duck.
      Edited 1/6/2009 7:09 pm ET by Riversong
Drafting the 2027 IRC
  • The New Old Colonial
