Raising a garage floor
oldeblue | Posted in Construction Techniques on October 7, 2004 03:17am
I purchased a derelict (to put it nicely) house at auction here in Texas.  A previous owner had enclosed the garage and turned it into a music room.  However, he did not address the 1 1/2″ step up from the garage floor to the apron at the front.  I want to eliminate the step as I plan to install a floating laminate wood floor over the entire room and then promote it as a home theater or game room during the sale.
I was thinking I could use 3/4″ treated sleepers 16″ OC followed by 3/4″ plywood.   Is this the right approach?  Someone suggested that I should pour concrete.  I’m not sure I like that approach but I am willing to entertain the idea.  What do you guys (gals?) think?
    ProBozo | Oct 07, 2004 03:30pm | #1
    #1 question is how level is the existing concrete floor. at a minimum, you'll have to scribe or shim the sleepers.
    1. brownbagg | Oct 07, 2004 03:37pm | #2
      I, myself would just pour a extra 1 2/3 of concrete. Then it would not leave a hollow for bugs to hide.
    2. oldeblue | Oct 07, 2004 04:37pm | #3
      Shimming to level the floor is not a problem.  What about a vapor barrier?  And should I use felt or anything between the sleepers and the plywood?
      1. Mitremike | Oct 09, 2004 07:16am | #6
        given the chance to lay down a VB -Why wouldn't you? True the treated sleepers wont rot but what about the vapor coming up thru the slab itself and attacking the ply --try putting down a 2 foot square piece of poly tape down to seal and see it you have any vapor migrating thru the slab--We all know how concrete is the moisture super highway.
        wait a minute i just saw you are from Texas right? Slab on grade? Maybe I'm throwing ####little up north info into a area that it doesn't apply. Well my box is creaking so I'd better get off before....aaahhhh to late. Mike
  2. oldeblue | Oct 08, 2004 11:45pm | #4
    Hmmm, Breaktime at a loss for opinion?  <G>  Surely not!
    1. FastEddie1 | Oct 09, 2004 02:05am | #5
      If you use treated sleepers, there's no reason to use felt.
      Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
