raising door height
silverparrot | Posted in Construction Techniques on April 17, 2008 04:27am
I am converting a door to a passage way through a bearing wall of 2×6’s.
Attached is a diagram of my plan.
My question is:
Can I leave the original 79″ 2×6, and add the 2×6 spacer above it.
or do I need to remove the 79″ 2×6 and add a new whole 2×6 up to the
bottom of the lintel.
Hope I am clear.
Thas
    JDRHI | Apr 17, 2008 04:34pm | #1
    Remove existing jack studs, raise header and replace with full length jacks to bottom of header.
    J. D. Reynolds
    Home Improvements
    Pp, Qq
    1. silverparrot | Apr 17, 2008 04:41pm | #2
      Thanks for your help!!
  2. Jim_Allen | Apr 20, 2008 06:57pm | #3
    It can be done either way but it's obvious that replacing the entire trimmer stud would be better. There are a dozen ways to skin a cat though.
    1. silverparrot | Apr 20, 2008 07:27pm | #4
      I was hoping to avoid the toil of digging out the spikes to remove the stud, but will
      do so if it means a stronger build.
      Thanks for you input.
      1. Jim_Allen | Apr 20, 2008 08:02pm | #5
        It might not need to be stronger but a nail puller will yank those nails in seconds so that can't be the only detterant.
        Is this wide open or are you tying to finesse something here? If you are trying to finesse it, I'd just do the fillin thing unless there was some serious point load above. Bob's next test date: 12/10/07
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
