Raising first story ceiling height and adding second story
addon | Posted in Construction Techniques on June 1, 2010 12:15pm
I am planning to add a second story onto a simple gabled-roof ranch.  I would like to raise the lower story ceiling height at the same time.  What is the best way to acheive this?
  1. Kevin_D | Jun 01, 2010 04:17pm | #1
    Foundation
    First you have to confirm that your existing foundation can support a 2nd story.
    If it can't then you have to underpin it or use a similar approach to beef it up.
    Out here in CA, I'd be leery of using an old existing foundation anyways, as depending upon the date poured it probably does not contain rebar.
    You have to get an engineer / architect and submit plans to your local building authority.
  2. DanH | Jun 01, 2010 08:15pm | #2
    Seriously, you'd probably be better off jacking up the current structure and putting a first floor under it.
  • Townhouse Transformation
