Raising living room floor using rigid foam
user-5593551 | Posted in Construction Techniques on October 31, 2018 08:33am
I have a second floor sunken living room that I would like to raise to the surrounding floor level. I am considering using rigid foam board to take up the space and hopefully reduce noise to the living space below. I would place plywood and flooring on top of the rigid foam. The supporting joists are adequate for the additional load.
Are there concerns or code issues with this approach? Would I be better off just taking up the space with 2Xs and adding sound attenuation on the underside?
  1. DanH | Oct 31, 2018 12:41pm | #1
    I'd be a little leery that the foam would compress over time, leading to squeeks and bounce.
    Perhaps the foam manufacturer would share some advice on this application.
      sawdust_steve | Oct 31, 2018 02:29pm | #2
      Not at all. The foam compressive stength is more than edequate. We frequentlyuse rigid foam beneath concrete slabs that are subjected to vehicular traffic
      1. DanH | Oct 31, 2018 09:15pm | #3
        But concrete spreads the load much more evenly than plywood.
  2. oldhand | Nov 02, 2018 09:59am | #4
    maybe...
    It's not unusual to have flooring over plywood over 1" polyiso foam on top of concrete floors. I think 1" Styrofoam actually has a c ompressive load rating. But I don't understand how much you need to raise your floor, probably a limit on how thick the foam can be. I also have seen a sound reduction rating for foam in a floor, it seems like it was impressive. I recently did a small area as described above in a remodel [lam over plywood over foam and it had a good feel to it.
