Re-Roof over interlock shingles
sledge | Posted in General Discussion on May 15, 2007 01:51am
Hi Folks.
I’m going to re-shingle my shop roof. I want to shingle over the interlock shingles with a 30 yr 3 tab shingle.
Will I see the shadow of the interlock under the 3 tab. The interlock are not in bad shape, no raised edges, but will need to be replaced sometime in the next 5-10 yrs. The interlock were rated 25yr when I put them on in 1983. I would like to do it this year because age is catching up and I want to get it done while I can do it myself.
I could take the interlock off but it would be easier to leave them on if possible.
Can I leave them on or should I do it the right way and strip off the old?
Thanks..
Ed
  1. Stilletto | May 15, 2007 01:54am | #1
    3 tabs will not hide interlocking shingles,  T-locks or Goslin shingles.
    Where they overlap is quite a bit thicker than the middle of the shingle,  the new shingles will highlight that.
      sledge | May 15, 2007 02:28am | #2
      Are you suggesting I re-roof with T-Lock or goslin?
      Ed
      1. Stilletto | May 15, 2007 02:36am | #4
        Yes,  it will hide the other layer alot better than 3 tabs.
  2. Dave45 | May 15, 2007 02:33am | #3
    I'm against putting new roofing over old under any circumstances.  My standard arguments are:
    • The old roof has probably been there for 20+ years and that means that the decking, rafters, flashing, etc hasn't been looked at (or repaired) for 20+ years, either!
    • Far too often, the old roof "telegraphs" thru the new one - and that seldom looks very good.
    • New shingle warranties are usually invalid unless they're laid on a clean deck.
    Edited 5/14/2007 7:34 pm by Dave45
  3. Piffin | May 15, 2007 06:13pm | #5
    using three tabs over the interlocks is a bad idea. It will shadow, llook bad, and not last as long as it would other wise.
    T-Locks were developed for two purposes, one was wind resistance, the other was for roofing over old cedar shingle roofs
