Re-Siding & Retro-fit job
BurgessBuilt | Posted in Energy, Heating & Insulation on January 7, 2013 01:03am
Hello All,
I’m going to be stripping the terrible old siding off of my house and wrapping it with rigid insulation and finishing with strapping and vicwest steel cladding.  Here’s the dilemma, I want to use Energy shield (ISO), probably 2.5 inches thick for the maximum R-value while still maintaining simplicity in the furring details.  But my house was built in the 70’s and is of 2×4 construction, and it has a 6mil poly stapled air barrier beneath the drywall, and I’m afraid that I will end up with moisture problems down the road.
Does anyone know a way around this while still sealing the Energy Shield or am I stuck with using XPS foam instead and settling with a lower R-value??
I would prefer not to install an HRV.
Thanks!
  1. DanH | Jan 07, 2013 06:48am | #1
    Where do you live?
  2. user-674428 | Jan 07, 2013 12:57pm | #2
    I'm no expert, but Roxul does have a very permeable rock wool board.. Comfort Board IS or something.   Saw it at Home Depot (Canada) and it is like a very still compressed Roxul batt.
    http://www.greenbuildingadvisor.com/blogs/dept/musings/installing-mineral-wool-insulation-over-exterior-wall-sheathing
    If you are northern US or Canada, it might be a worth looking into..
Mortar for Old Masonry
