Rebar chair spacing??
bigman | Posted in Construction Techniques on June 11, 2005 03:07am
Hello, I plan on using #3 rebar in an 18″ grid pattern on 2″ chairs for my garage and basement slabs (4000 sq ft @ 3500 psi/Fibermesh) and was wondering if I space the chairs at 18″ or can I go to 36″ spacing?. I can’t seem to get a straight answer from the concrete guys I know, they all use wire mesh and say the rebar is useless, but it seems to me the mesh always ends up in the bottom of the slab.
  1. brownbagg | Jun 11, 2005 04:00pm | #1
    you can space as big as you want as long as the rebar off the ground.
  2. Notchman | Jun 11, 2005 04:41pm | #2
    As Brownbag says.
    But I always use 'dobes, the little concrete blocks made for the same purpose.  Get the ones with the wires.  Usually come in 2" or 3".
    Those metal chairs are a PITA...often flip over and drop the bar during the pour.
    1. RalphWicklund | Jun 11, 2005 04:56pm | #3
      <<Those metal chairs are a PITA...often flip over and drop the bar during the pour.>>
      Wire ties are cheap insurance for that problem.
      1. Notchman | Jun 11, 2005 11:12pm | #4
        Even with wire.   I still prefer the adobes
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
