I am rebuilding some wood awning and casement windows and have had to replace one section that was beyond repair. The windows have a small groove runing around the outside edge into which a piece of vinyl weather strip is inserted. This weather strip seals the gap between the operating part of the window and the exterior frame when the window is closed. The groove is about 3/32″ wide and about 1/4″ deep. I can’t seem to figure out what kind of a tool or blade I would need to make this grove. I have looked for Dremel or router bits but haven’t seen anything this small. I wonder if you can get a sawblade this thin? Does anyone have any ideas? Thank you.
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
You can use a slotting router bit. The depth of cut is controlled by the bearing or fence on a router table.
http://www.coastaltool.com/a/amana/slotting.htm
Rebuilding a wood window
Great suggestion. I don't know why I didn't think of that, but I think it will work perfectly. Thanks a lot.
HI..
Thanks for asking the question and as well as for the answer provided..Because this is exactly the information that i was searching for past one week..Same problem i had with my wooden window with some variation..And the answer provided was perfectly fine..
