Receptacles in PVC column?
FR | Posted in Energy, Heating & Insulation on February 28, 2010 04:36am
Guys,
I’m wrapping pt 4x4s porch columns with 8 inch pvc column wraps.   Can the receptacles be mounted directly into the pvc or do they have to be mounted onto the 4x4s with a box extender out through the PVC?  I wasn’t sure if fastening the box to the pvc was ok.   PVC is 5/8″.
Thanks for your input.
FR
    MarkH | Feb 28, 2010 06:55pm | #1
    I can't see any reason not to mount the box to the PVC wrap except if you want to limit stress on the PVC wrap itself. PVC holds screws pretty well.
    I would probably attach a scab onto the post to screw the box into if you're worried about stress on the wrap.
